I have recently acquired a small Emerson AM set. Looks like a late 1930's set with a small wooden case, 2 knobs and a small rotary dial with a square bezel.The speaker grill is a number of long vertical slots cut in the wooden case.
The tube lineup is ( and they ARE packed in!! ):
25Z6 Rect , 50L6 Audio , 6A8 Converyer, 6K7 IF, 6Q7 Det 1st Audio, #44 pilot lamp ( I think I got all of those right! ).This model does seem to have some line dropping resistance in the line cord.
Can anyone help me find the model number? The back is missing on this one and hence the model number.
Thanks in Advance
Lou
http://radioatticarchives.com/archive.htm?page=e2#Emerso
![]() Sir Lou. . . . Consulting the printout from Yaxley below, the YELLOW highlighting is designating the use of a 6SQ7 vice 6Q7, while some of the cases, refer to both numbers.
I would add one thing to Edd comment. He is correct the 50L6 will be very bight but don't turn the radio on with this tube. Wait until you get a 25L6 for output.
The 50L6 may burn out as other tubes will add very little series resistance. Other tubes won't even light.
:Gentlemen:
:I have recently acquired a small Emerson AM set. Looks like a late 1930's set with a small wooden case, 2 knobs and a small rotary dial with a square bezel.The speaker grill is a number of long vertical slots cut in the wooden case.
:The tube lineup is ( and they ARE packed in!! ):
:25Z6 Rect , 50L6 Audio , 6A8 Converyer, 6K7 IF, 6Q7 Det 1st Audio, #44 pilot lamp ( I think I got all of those right! ).This model does seem to have some line dropping resistance in the line cord.
:Can anyone help me find the model number? The back is missing on this one and hence the model number.
:Thanks in Advance
:Lou
One thing you could do is use all 150 ma filament tubes. Then you wouldn't need series ballast resistance.
In that case leave the 50L6 and change others to 12 volt @ 150 ma tubes. 6A8 to 12A8, 6K7 to 12K7, 6Q7 to 12Q7, 25Z6 to 50Y6. Could use a 35L6 for 50L6. Either would work.
:Hi Lou
: I would add one thing to Edd comment. He is correct the 50L6 will be very bight but don't turn the radio on with this tube. Wait until you get a 25L6 for output.
: The 50L6 may burn out as other tubes will add very little series resistance. Other tubes won't even light.
::Gentlemen:
::I have recently acquired a small Emerson AM set. Looks like a late 1930's set with a small wooden case, 2 knobs and a small rotary dial with a square bezel.The speaker grill is a number of long vertical slots cut in the wooden case.
::The tube lineup is ( and they ARE packed in!! ):
::25Z6 Rect , 50L6 Audio , 6A8 Converyer, 6K7 IF, 6Q7 Det 1st Audio, #44 pilot lamp ( I think I got all of those right! ).This model does seem to have some line dropping resistance in the line cord.
::Can anyone help me find the model number? The back is missing on this one and hence the model number.
::Thanks in Advance
::Lou
Thanks for the input.
If I do change the string filament values, how to I keep the pilot lamp? There would be no available tap ready for the lamp.
Lou
:Hi
: One thing you could do is use all 150 ma filament tubes. Then you wouldn't need series ballast resistance.
: In that case leave the 50L6 and change others to 12 volt @ 150 ma tubes. 6A8 to 12A8, 6K7 to 12K7, 6Q7 to 12Q7, 25Z6 to 50Y6. Could use a 35L6 for 50L6. Either would work.
::Hi Lou
:: I would add one thing to Edd comment. He is correct the 50L6 will be very bight but don't turn the radio on with this tube. Wait until you get a 25L6 for output.
:: The 50L6 may burn out as other tubes will add very little series resistance. Other tubes won't even light.
:::Gentlemen:
:::I have recently acquired a small Emerson AM set. Looks like a late 1930's set with a small wooden case, 2 knobs and a small rotary dial with a square bezel.The speaker grill is a number of long vertical slots cut in the wooden case.
:::The tube lineup is ( and they ARE packed in!! ):
:::25Z6 Rect , 50L6 Audio , 6A8 Converyer, 6K7 IF, 6Q7 Det 1st Audio, #44 pilot lamp ( I think I got all of those right! ).This model does seem to have some line dropping resistance in the line cord.
:::Can anyone help me find the model number? The back is missing on this one and hence the model number.
:::Thanks in Advance
:::Lou
I decided to take out the old resistance line cord (that was broken anyway) and put in the appropriate values of power resistors to satisfy the drop requirement AND the pilot lamp. Not quite original but it will play and be safer!!
Lou
:If you have room for a 120 volt 4 watt night light bulb, that will solve the problem. A lot of radios use this as a dial lamp. Very little heat, just feels warm to the touch.
