Please help if you can.
:I would bet it has a crack in the PC board. Most like where the point of impact. Take all the covers off, look around all the edges where it connects to the metal frame. Tighten up all the ground screws while your at it.
:Warren,
: I have checked the PC boards with a very bright lamp and can find no such broken lands or cracked boards. I am going to need to find the schematic or at least the model number so I can find the schematic. Then I can do some troubleshooting.
:Thanks,
:Dave
::I would bet it has a crack in the PC board. Most like where the point of impact. Take all the covers off, look around all the edges where it connects to the metal frame. Tighten up all the ground screws while your at it.
:Hello All,
: I do have sound from one channel. I have the thump from both channels but one has no sound. The balance control is good. So what may have broken? Where do I look? With no service data, I am lost.
:Dave
::Warren,
:: I have checked the PC boards with a very bright lamp and can find no such broken lands or cracked boards. I am going to need to find the schematic or at least the model number so I can find the schematic. Then I can do some troubleshooting.
::Thanks,
::Dave
:::I would bet it has a crack in the PC board. Most like where the point of impact. Take all the covers off, look around all the edges where it connects to the metal frame. Tighten up all the ground screws while your at it.
:Does it have sound on both channels in the AM mode? That should tell you if it's an FM problem, or in the audio path common to both AM an FM. You said it was working before it got bent in shiping. I would still think there is an open other than componet fail. Try and flex and probe the circuit board while it's playing. You could also do some simple testing, as to use the working channels voltage path,compaired to the non working one.
http://cgi.ebay.com/ebaymotors/1975-80-PONTIAC-FIREBIRD-TRANS-AM-AM-FM-RADIO_W0QQitemZ3601785
:Google 1976 pontiac trans am radio. Ebey motors did show a listing.
Thanks anyway,
