:::Touchy thing to try. Depending on what the dial face is made from. if it will flex a little, maybe try to clamp it slightly on a flat piece of wood. hold a hair dryer just close enough to warm it. Tighten the clamp a little more. keep doing this until its where it needs to be. If you get it too hot, it could just shrink. Or if it's hard plastic, to much clamping may snap it. Good Luck.
Scott, I thought of that myself on a warped Zenith dial - but was scared off when I heard that some people got good results from pressing it - like inside a heavy book - and leaving it like that for a few weeks. I "pressed" my large celluloid Zenith dial this way and left it in storage months ago. I haven't taken it back out for a look yet, but from comments from others - I expect it will be a good flat dial by the time I take it out.
Eddie
:Thanks for the ideas...yes it is old brittle plastic but I will try this easy heat method that you two gentlemen suggested and see what happens,
