GE AM Clock Radio - Back Removal
8/4/2009 9:46:48 PMcm
Got a model C-446A and I'm trying to get the back off to re-cap and generally clean things up. This one has 4 push button keys to the left (under the clock movement) and a slide rule tuner to the right.
Anyway have the back completely undone and loose however the knob for changing the alarm/clock time is bigger than the hole in the back! Don't know if it's a replacement.
The instructions for removing the back are printed on the bottom but don't mention this knob so perhaps it's a replacement.
Any ideas on how to get this sucker off? Short of cutting it off? Is the knob screwed on the shaft? Or pressed on?
Am I asking too many questions???
Thanks in advance.
8/4/2009 10:11:52 PMNorm Leal
Hi
There were clock knobs screwed on a shaft in back. With a needle nose pliers hold the shaft and see if the knob unscrews.
:Got a model C-446A and I'm trying to get the back off to re-cap and generally clean things up. This one has 4 push button keys to the left (under the clock movement) and a slide rule tuner to the right.
:Anyway have the back completely undone and loose however the knob for changing the alarm/clock time is bigger than the hole in the back! Don't know if it's a replacement.
:The instructions for removing the back are printed on the bottom but don't mention this knob so perhaps it's a replacement.
:Any ideas on how to get this sucker off? Short of cutting it off? Is the knob screwed on the shaft? Or pressed on?
:Am I asking too many questions???
:Thanks in advance.
8/4/2009 11:00:48 PMWarren
The clock in that GE is a Telechron. To remove the knob hold the shaft with needle nose pliers. If I remember right, it may be reverse threaded. You could heat the knob a little with a clean soldering gun tip. Twist the knob a little each way, it will unscrew.
8/5/2009 5:48:57 AMcm
Norm, Warren,
Thanks I'll give the pliers a try. I like the idea of applying some heat too.
cm
