Bill
You mentioned a new battery but be sure it has full voltage and good contacts. The RX1 scale draws a lot of current in this meter and doesn't zero if the battery has a poor contact.
An internal resistor may have changed value but usually it's the battery for RX1 scale.
: Hello, I have a Simpson 260-6P VOM which I bought used a
: while back. It is in fine physical shape, no internal
: corrosion on battery terminals, etc. However, I cannot
: get the meter to zero on the Rx1 scale. It continues to read
: about 5 ohms with a new battery and a short jumper across
: the positive and common terminals. If anyone out there
: has Simpson repair experience I have a few questions to
: ask that might help me identify the problem, which I suspect
: may be in the internal resistor values since all other
: functions and ranges seem to work fine. Any help is
: appreciated.
: Bill
Thanks again
: Hi Bill
: You mentioned a new battery but be sure it has full voltage and good contacts. The RX1 scale draws a lot of current in this meter and doesn't zero if the battery has a poor contact.
: An internal resistor may have changed value but usually it's the battery for RX1 scale.
: Norm
: : Hello, I have a Simpson 260-6P VOM which I bought used a
: : while back. It is in fine physical shape, no internal
: : corrosion on battery terminals, etc. However, I cannot
: : get the meter to zero on the Rx1 scale. It continues to read
: : about 5 ohms with a new battery and a short jumper across
: : the positive and common terminals. If anyone out there
: : has Simpson repair experience I have a few questions to
: : ask that might help me identify the problem, which I suspect
: : may be in the internal resistor values since all other
: : functions and ranges seem to work fine. Any help is
: : appreciated.
: : Bill
