GTD --- DTM --- + --- DTS
The schematic only shows 3 points A - Z - G
http://www.nostalgiaair.org/Resources/207/M0025207.htm
So what's the right meaning or correlation as to what is what?
On the chassis inside the wiring is:
GTD - is going to the same point as "A" on the print (antenna coil primary)
DTM - goes to the same as "Z" on the print which goes to the rotary switch.
+ connects to nothing.
DTS - is hard wired to the chassis.
The print shows an optional jumper from Z to G
The radio operates best for Broadcast AM w/the long wire antenna connected to GTD and enhanced reception on ShortWave with an earth ground (water-pipe) on DTM
But should the jumper be connected too?
A little enlightenment please?
Looks like you have the coincidence of the GTD-DTM-DTS correctly correlated , but I might only guess as to the "T" aspect being for terminal.
