7/29/2009 6:06:33 PMTom (77220:0)
Hi, I have a Bogen SRB40. It plays stereo fine through the aux. inputs. If I loop the FM MPX output to MPX input it plays stereo fine. The problem is in the AM. If I switch to AM it plays through only one channel. Does anyone have any experience with this uint?
7/29/2009 6:22:39 PMLewis L(77223:77220)
:Hi, I have a Bogen SRB40. It plays stereo fine through the aux. inputs. If I loop the FM MPX output to MPX input it plays stereo fine. The problem is in the AM. If I switch to AM it plays through only one channel. Does anyone have any experience with this uint?
I don't have a schematic, but I can guess this:
The unit was not designed for AM stereo, so both channels are tied togher for AM. Since both channels are working on FM stereo, then both channels should be working on AM. Maybe your problem is nothing more complicated than a rotary switch with a dirty contact,
give all of the rotary switch contacts a good scoot with a contact cleaner, and "exercise" them a little, and let me know what happened.
7/29/2009 8:39:18 PMTom(77231:77223)
::Hi, I have a Bogen SRB40. It plays stereo fine through the aux. inputs. If I loop the FM MPX output to MPX input it plays stereo fine. The problem is in the AM. If I switch to AM it plays through only one channel. Does anyone have any experience with this uint?
:I don't have a schematic, but I can guess this:
:The unit was not designed for AM stereo, so both channels are tied togher for AM. Since both channels are working on FM stereo, then both channels should be working on AM. Maybe your problem is nothing more complicated than a rotary switch with a dirty contact,
:give all of the rotary switch contacts a good scoot with a contact cleaner, and "exercise" them a little, and let me know what happened.
7/30/2009 4:47:01 PMEdd(77262:77231)
SIR Tom. . . . .
It seems that 60’s vintage of unit was fully capable of the stereo handling aspect when using the phono or tape input portion.
As far as the radio aspect it was able to handle FM stereo if its output was fed into a separate stereo decoder and then being fed back into the unit.
Now as per your queried AM aspect, I remember just a wee bit of a select few hours that a station would devote to the transmission of one channel of stereo thru FM transmission and its companion other channel thru AM radio, thus acquiring the stereo effect.
That was just to prove out to be a novelty of the time. That was soon to be done again with AM stereo radio many years later, with it also never catching on.
Then as for your REAL info, in consulting your units attached schematic, one sees that in the AM radio mode the switching is diverting the AM audio solely to the CHAN 2 output. Read my far right [ YELLOW HIGHLIGHTING ] and its red referencing.
I have also placed in the AM radio [GREEN-DOTS] and the FM radio [BLUE-DOTS], input routings to the selector switch S14—sections 2 and 4 rears.
Now if you really want it, you could provide additional switching action to route the AM signal additionally into CHAN 1, so you would then have a more pleasant mono source filling the room . . . .BUT. . . with it then being binaural mono !
