Precision Tube tester 612
3/11/2001 4:28:31 PMRoss
Does anyone know how to use the adapter that allows this tube tester to test the large 9 pin Noval, Compactrons, and nuvistors on this tube tester.
3/16/2001 12:38:25 PMTim
Ross:
I have the instructions for this add-on and the text mentions to plug the adapter into the 9 pin miniature socket and connect the plate cap lead to the stud on the adapter unless the tube under test has a plate cap.
If you need settings for a particular tube let me know.
Tim
: Does anyone know how to use the adapter that allows this tube tester to test the large 9 pin Noval, Compactrons, and nuvistors on this tube tester.
: Thanks
3/16/2001 12:44:29 PMTim
Ross:
The manual for the 614/614 is located in the Manuals Section of this site. It may have the info you need.
Tim
: Ross:
: I have the instructions for this add-on and the text mentions to plug the adapter into the 9 pin miniature socket and connect the plate cap lead to the stud on the adapter unless the tube under test has a plate cap.
: If you need settings for a particular tube let me know.
: Tim
: : Does anyone know how to use the adapter that allows this tube tester to test the large 9 pin Noval, Compactrons, and nuvistors on this tube tester.
: : Thanks
3/24/2001 2:11:01 PMRoss
: Ross:
: Tim
: : Thanks
I have a question for you. The settings for the 12-pin compatron tubes show that
you need to insert tube in the socket with key at #. # represents a number. How do
you determine which pin is the key? Thanks.
Ross
