Dummy antenna
3/11/2001 3:43:37 PMSteve
The circuit diagram for my Airline model 84WG-2714-g
calls for the Signal Generator to be connected through a dummy antenna. An old radio book provides a wiring diagram as .. .0002 mfd cap wired in series with a parallel circuit consisting of 1) a 20 uH coil and 2) a .0004 mfd cap and 400 ohm resistor in series.
I have 22, 26 & 30 gauge magnet wire and was thinking of winding the wire on either a small diameter dowel or nail. Am I on the right track here?
Can someone help with a formula (# turns, nail versus dowel, air etc.) to wind a 20 uH coil?
Steve
3/12/2001 10:09:48 PMBart
Steve, the schematics that I have either use a .1 MFD capacitor for a dummy antenna ( one lead connected to the signal generator and the other to the given point in the circuit ) or say to loop several turns of wire and connect the signal generator across the coil. The coil acts as transmitting antenna for the signal generator. I hope that works. Bart
: The circuit diagram for my Airline model 84WG-2714-g
: calls for the Signal Generator to be connected through a dummy antenna. An old radio book provides a wiring diagram as .. .0002 mfd cap wired in series with a parallel circuit consisting of 1) a 20 uH coil and 2) a .0004 mfd cap and 400 ohm resistor in series.
: I have 22, 26 & 30 gauge magnet wire and was thinking of winding the wire on either a small diameter dowel or nail. Am I on the right track here?
: Can someone help with a formula (# turns, nail versus dowel, air etc.) to wind a 20 uH coil?
: Thanks
: Steve
3/13/2001 12:16:25 AMdavep
The formula is;
L= self inductance in microhenrys,
N= total number of turns
R= mean radius in inches
l = length of coil in inches
B= depth of coil in inches
Single wound coils,
L= (rN)squared over 9r+10L
N= squareroot/L(9r+10L) over R
Wire Gauge or AUG:
22 = .02535
26 = .01594
30 = .01003
From Allied's radio data handbook 1943
: Thanks
: Steve
3/13/2001 12:23:55 AMdavep
sorry, should be a 10(length) in both those formulas
(it would appear as 10l)!
: The formula is;
: L= self inductance in microhenrys,
: N= total number of turns
: R= mean radius in inches
: l = length of coil in inches
: B= depth of coil in inches
: Single wound coils,
: L= (rN)squared over 9r+10L
: N= squareroot/L(9r+10L) over R
: Wire Gauge or AUG:
: 22 = .02535
: 26 = .01594
: 30 = .01003
: From Allied's radio data handbook 1943
: : The circuit diagram for my Airline model 84WG-2714-g
: : calls for the Signal Generator to be connected through a dummy antenna. An old radio book provides a wiring diagram as .. .0002 mfd cap wired in series with a parallel circuit consisting of 1) a 20 uH coil and 2) a .0004 mfd cap and 400 ohm resistor in series.
: : I have 22, 26 & 30 gauge magnet wire and was thinking of winding the wire on either a small diameter dowel or nail. Am I on the right track here?
: : Can someone help with a formula (# turns, nail versus dowel, air etc.) to wind a 20 uH coil?
: : Thanks
: : Steve
3/16/2001 10:46:01 PMSteve
: Thanks
: Steve
I will give it a try.
Steve
