Buckingham floor model radio
7/25/2009 12:02:58 PMMike Armiger
I am looking for info on this radio: Buckingham floor model radio. Serial # 27785. 2 knobs, sliding doors that meet conseal the dial, it has 7 or 8 tubes + one that is larger. Is it a rectifier?
7/25/2009 12:46:47 PMWarren
More information is needed. Model number? Tube numbers?
The basic lay out of the chassis. What is the number on that " big tube " could be an 80 rectifier.
7/25/2009 7:18:48 PMMike Armiger
:I am looking for info on this radio: Buckingham floor model radio. Serial # 27785. 2 knobs, sliding doors that meet conseal the dial, it has 7 or 8 tubes + one that is larger. Is it a rectifier?
Basic layout:7 tubes across the back(all RCA/Raidotron
RCA 80 Rectifier-26-uy227-26-26-26-71A...No Model# found
7/25/2009 7:34:25 PMBill G.
Hi Mike,
Sounds a lot like a Radiola. I had a Radiola 17 that had that rube line up.
It had corroded power resistors and was miserable to work on.
However yours ir much better I am sure. Radiola 17 dated from 1927.
Best Regards,
Bill Grimm
7/25/2009 8:00:24 PMMike Armiger
:Hi Mike,
: Sounds a lot like a Radiola. I had a Radiola 17 that had that rube line up.
: It had corroded power resistors and was miserable to work on.
: However yours ir much better I am sure. Radiola 17 dated from 1927.
:Best Regards,
:Bill Grimm
Thanks Bill. It is in great condition but I have not been able to toy with much. The dial does not work & I don't think it powers up. Sellers are asking 150.00
7/25/2009 10:00:03 PMBill G.
::Hi Mike,
:: Sounds a lot like a Radiola. I had a Radiola 17 that had that rube line up.
:: It had corroded power resistors and was miserable to work on.
:: However yours ir much better I am sure. Radiola 17 dated from 1927.
::Best Regards,
::Bill Grimm
:Thanks Bill. It is in great condition but I have not been able to toy with much. The dial does not work & I don't think it powers up. Sellers are asking 150.00
Hi Mike,
Since you are unsure of the model number take the schematic with a grain of sault.
RCA tended to not mark their parts, most annoying. When I got into the radio I found an open resistor painted brown. I thought it was, brown-brown-brown, 110 ohms.
No, it was just painted that way. The resistor wasn't open, it was 1 meg.
Best Regards,
Bill Grimm
7/25/2009 10:11:05 PMNorm Leal
Hi Mike
Buckingham Model 80 matches those tubes but has 2 - 71A's. There are only 4 Buckingham schematics in Rider:
http://www.nostalgiaair.org/Resources/069/T0000069.htm
::I am looking for info on this radio: Buckingham floor model radio. Serial # 27785. 2 knobs, sliding doors that meet conseal the dial, it has 7 or 8 tubes + one that is larger. Is it a rectifier?
:Basic layout:7 tubes across the back(all RCA/Raidotron
:RCA 80 Rectifier-26-uy227-26-26-26-71A...No Model# found
7/26/2009 1:21:55 AMMike Armiger
Thanks Neal, I got the schematics. What value could be placed on this radio if it works?
Posting IPAddress: 74.181.210.8
