The fat prong, the cold side of the power goes to the switch. This is preferred because the switch also has the volume control. A high AC voltage on the switch when turned on can couple to the sensitive signals in the volume control, resulting in hum.
Best Regards,
Bill Grimm
::Ok I have asked this question before..and I can not remember...(This time I am going to write it down LOL) I am currently working on a 1936 Fairbanks Morse chasssis model 72. The line cord goes to switch and other end is connected to transformer and a large mica cap (mica cap is in turn connected to chasis) Chassis is ground on this set. MY QUESTION IS...Does the fat prong of polarized cord go to transformer and "thin" prong go to switch..? I would appreciate it if someone could explain this to me..I know you do this different in other types of sets. For the most part I collect late 1920-45 AC sets. When doing line cord I wana be sure I am doing it right so when i touch chassis I won't get a lethal shock LOL... THANK FOR ANY HELP>>>>
:The fat prong, the cold side of the power goes to the switch. This is preferred because the switch also has the volume control. A high AC voltage on the switch when turned on can couple to the sensitive signals in the volume control, resulting in hum.
:Best Regards,
:Bill Grimm
::Ok I am confused..I was told small prong to switch...hmmm When is this done then?
::::Ok I have asked this question before..and I can not remember...(This time I am going to write it down LOL) I am currently working on a 1936 Fairbanks Morse chasssis model 72. The line cord goes to switch and other end is connected to transformer and a large mica cap (mica cap is in turn connected to chasis) Chassis is ground on this set. MY QUESTION IS...Does the fat prong of polarized cord go to transformer and "thin" prong go to switch..? I would appreciate it if someone could explain this to me..I know you do this different in other types of sets. For the most part I collect late 1920-45 AC sets. When doing line cord I wana be sure I am doing it right so when i touch chassis I won't get a lethal shock LOL... THANK FOR ANY HELP>>>>
:::The fat prong, the cold side of the power goes to the switch. This is preferred because the switch also has the volume control. A high AC voltage on the switch when turned on can couple to the sensitive signals in the volume control, resulting in hum.
:::Best Regards,
:::Bill Grimm
:Bill, thanks. DadGummit, I've tended to put the switch on the hot side - that way, when the switch is OFF, most of the chassis wiring is de-energized. I hadn't thought about hum.
:Doug
::Best Regards,
::Bill Grimm
Best Regards,
Bill Grimm
If the hum is acceptable, I wouldn't change it for radios that you've already restored.
The hum that would result from coupling to the power switch should be 60-Hz hum, not the 120-Hz hum that is typical of full-wave rectifiers use on AC sets.
Doug
:Best Regards,
:Bill Grimm
We should remember that polarized plugs weren't around yet when most of these radios were built.
There was a 50/50 chance that when the set was plugged in back then that the hot side of the line would end up on the power switch.
The manufacturers didn't think it was a significant detriment to the set's performance then. I'm not sure it is today.
