Since you are indicating that the cap has polarity marked on it... then it is probably an electrolytic so in that case it is ..probably a bleeder resistor to discharge the cap when shut off.
However if the resistor is in the cathode of the output amp tube with an electrolytic in parallel .. then in that case the resistor is used for "cathode bias" so the grid bias can have a negative reference.
The parallel cap in that case is called the cathode "by-pass" cap and is used to stabilize the cathode voltage when the grid signal swings are turning the tube on a good deal drawing more current causing the cathode resistor to have a greater voltage drop.
That causes signal distortion ( negative feed back) and so to counter that...the cap stabilizes and reduces those variations... keeping the grid bias reference point stable.
:::Hi all ..A quick question.... I noticed that in a few of the 1930s-40s radios that I have restored there are capacitors that are coupled with a resistor..Or in other words a resistor is "piggy backing" on a cap by being connected to both the + and - leads of cap...What exactly is the purpose of this... THANKS...
::Since you are indicating that the cap has polarity marked on it... then it is probably an electrolytic so in that case it is ..probably a bleeder resistor to discharge the cap when shut off.
::However if the resistor is in the cathode of the output amp tube with an electrolytic in parallel .. then in that case the resistor is used for "cathode bias" so the grid bias can have a negative reference.
:: The parallel cap in that case is called the cathode "by-pass" cap and is used to stabilize the cathode voltage when the grid signal swings are turning the tube on a good deal drawing more current causing the cathode resistor to have a greater voltage drop.
::That causes signal distortion ( negative feed back) and so to counter that...the cap stabilizes and reduces those variations... keeping the grid bias reference point stable.
Still most likely cathode-by-pass on IF stages
Why not post the radio id and schematic instead of generalities?
