Radio Id Help
7/10/2009 10:45:44 AMJames Behler
Hi Guy's;
I just purchased this radio from an older gentlemen the other day and I can't seem to find it anywhere to get a schematic.
It is a Co-Op brand wood table top and the modwel says 6G.
The tube line up is as follows; From left to right in back are 80, 6D6 and a 75. Behind coil in middle are 6A7 and a 76 and behind the 75 is a 41.
I don't know how to post pictures so I can't give you that.
Any help would be appreciated greatly.
Jim
Ad-Vintage Radio
jbehler@new.rr.com
7/10/2009 12:26:58 PMCarl T
:Hi Guy's;
:I just purchased this radio from an older gentlemen the other day and I can't seem to find it anywhere to get a schematic.
:It is a Co-Op brand wood table top and the modwel says 6G.
:The tube line up is as follows; From left to right in back are 80, 6D6 and a 75. Behind coil in middle are 6A7 and a 76 and behind the 75 is a 41.
:I don't know how to post pictures so I can't give you that.
:Any help would be appreciated greatly.
:Thanks
:Jim
:Ad-Vintage Radio
:jbehler@new.rr.com
Jim,
The RPC 7G chassis has the same tubes but also has an eye tube:
http://www.nostalgiaair.org/PagesByModel/138/M0016138.pdf
Carl T
7/10/2009 12:50:20 PMJames Behler
Hi Carl;
Thanks for the info and It looks like the same top and bottom, but like you mention the eye tube. So I should be able to use it.
Thanks Again
Jim
Ad-Vintage Radio
jbehler@new.rr.com
7/10/2009 7:54:46 PMBill VA
::Hi Guy's;
::I just purchased this radio from an older gentlemen the other day and I can't seem to find it anywhere to get a schematic.
::It is a Co-Op brand wood table top and the modwel says 6G.
::The tube line up is as follows; From left to right in back are 80, 6D6 and a 75. Behind coil in middle are 6A7 and a 76 and behind the 75 is a 41.
::I don't know how to post pictures so I can't give you that.
::Any help would be appreciated greatly.
::Thanks
::Jim
::Ad-Vintage Radio
::jbehler@new.rr.com
:Jim,
:The RPC 7G chassis has the same tubes but also has an eye tube:
:http://www.nostalgiaair.org/PagesByModel/138/M0016138.pdf
:Carl T
This is it? http://www.nostalgiaair.org/PagesByModel/007/M0003007.pdf
Bill
7/11/2009 9:31:57 AMJames Behler
:::Hi Guy's;
:::I just purchased this radio from an older gentlemen the other day and I can't seem to find it anywhere to get a schematic.
:::It is a Co-Op brand wood table top and the modwel says 6G.
:::The tube line up is as follows; From left to right in back are 80, 6D6 and a 75. Behind coil in middle are 6A7 and a 76 and behind the 75 is a 41.
:::I don't know how to post pictures so I can't give you that.
:::Any help would be appreciated greatly.
:::Thanks
:::Jim
:::Ad-Vintage Radio
:::jbehler@new.rr.com
::Jim,
::The RPC 7G chassis has the same tubes but also has an eye tube:
::http://www.nostalgiaair.org/PagesByModel/138/M0016138.pdf
::Carl T
:This is it? http://www.nostalgiaair.org/PagesByModel/007/M0003007.pdf
:Bill
Hi Bill;
You got it right on the head with no eye tube.
Thanks a million.
Jim
Ad-Vintage Radio
jbehler@new.rr.com
