Sir Vinod . . . .
Here's your Emud info and I will get you started on it, without even having to pull the chassis.
Initially, we can confirm that the fuse is intact, since you have filaments and pilot lamps.
Now, locate the AF output tube. . .EL84 . . .pull it and note the missing pins gap and then start a clock wise count, with the first pin being pin number 9 and then 8 and then 7. . . .and thats it, with you now making a mark on the chassis beside pin numbers 9 and 7. replace the tube in its socket but leave it not fully seated such that there is about a 3-4 mm gap so that a meter probe can then be able to reach in to touch a pin to take a measurement.
Now, you get the set plugged in and its tubes glowing, take DC metering in hand and chassis ground the negative meter probe and use the + probe to take a measurement of the main B+ (I highlighted in RED, on the mark-up schema.) which ends up at pin 7 BLUE buss of that EL84 tube. We are hoping for ~260-270 VDC B+. . . if there, GOOD, then you move over to the marked pin 9 and see what voltage is there, if low, or nothing suspect the YELLOW BOX marked up R39 as being bad, therefore not getting any sub B+ to the EL84's screen grid. . .or MORE IMPORTANTLY, the rest of the sets voltage supply, as is being depicted with the FUSCIA arrows path.
( I only chose FUSCIA, as the typically used color code of orange does not show up contrasting enough aside the RED main B+)
If voltage is present there the next move would to be testing and confirming that plate and screen voltages on the rest of the tubes are present.
That's about it for now. . . .standing by
