Sir Joe . . . .S
I also tend to concur on the excess voltage aspect. SINCE the set is using coated, fine- filament, battery type powered tubes, so things happen in a hurry.
If using a conventional heater- cathode tube lineup, the hot- cold. . . .emission - no emission . . . inertia would be greatly p r o l o n g e d out with that type of tube. With YOUR sets tube types, that burst of sound cycle is probably ocurring within just a few seconds.
So, I can see the unplugging of the set and the diminishment of the DC supply voltages, with that critical voltage threshold being approached and the then presence of sound . . . ..but .. BUT.. . the filaments have already chilled down, so there was but a very- very short timespan of any sound coming forth.
You did not specify if the isolation transformer was also incorporating a Variac feature, or even opting for taps to adjust the AC output voltage. . .like the RCA Vari-Tap series does. . . .assuredly not.. . .or you would have tried reducton.
If that was my set to analyze, I would be hooking it up to the isolation transformer where it was working and then consulting the schemtic , we now see the specified benchmark for the power supply written just above first electrolytic C13 as being 100 VDC.
Log that down and then move on up to the plates and screens of all of the tubes and log in their voltages. Those being in the 87 and 92 vdc range at the 3V4 output, 18vdc for the 1S5, 92vdc for the 1U4 and 92 and 66vdc for the 1R5.
Now, when you power up the set from the full AC LINE source , somehow, I am expecting the 100 vdc test point to be up quite a bit, in fact so much that it resilts in the shifting of the biasing paramenter of tubes such that they're driven into heavier conduction and a shifting of those plate voltages and a cessaton of amplification.
Now, when you unplugged the set, there was a DC power reserve stored in the electrolytics , but no incoming power refresh, so the DC level started being pulled down. . . .until drain resulted in voltage decline. . . . UNTIL that magic threshold was hit where set amplification initiated again, but, by that time the filaments were cold.
Considering that you replaced that selenium rectifier with a modern !N4007 family, you went from an ~ decade of voltage drop in passing thru a selenium rectifier to a mere .7 volt in its passage thru a silicon diode.
That R8 140 ohm 3 watt surge / dropping resistor, needs to be inceased in value, in order to bring the B+ supply level back down to that specified 100 VDC at its test point.
Wouldn't hurt to also check each filament voltage to also see how close they are to spec and them also not being oversupplied with voltage.. . .with like due consideration of potential filament longevity, as well as not excessively depleting the filament coating emissivity chemicals.
