Here's the way I would do it:
Get a SPDT switch, a phonop jack and some hook-up wire. Go to the hot side of the volume control, that is where the slider is when the volume is full on, and disconnect the wire there. Wire the common of the switch to the volume control terminal where you disconnected a wire. Connect (or replace with a new piece of wire) the wire you disconnected from the volume control to one side of the SPDT switch, and connect the remaining switch terminal to the phono jack. Coonnect the ground side of the jack to the low side of the volume control. Use the switch to connect to phono or radio. Et voila, there you are.
Lewis.
SPDT SW.
RADIO----------o\ VOLUME CONTROL
HI \o--------\/\/\/\/----GND
PHONO >------o | /
LO |
to audio sectiom
7/7/2009 9:53:01 PMAnyone see a picture laying around. . . .?(75799:75754) :::A friend asked me to install a phono jack in his Motorola model C16P. How would I do that? Do I have to use a switch? :: ::Here's the way I would do it: :: Get a SPDT switch, a phonop jack and some hook-up wire. Go to the hot side of the volume control, that is where the slider is when the volume is full on, and disconnect the wire there. Wire the common of the switch to the volume control terminal where you disconnected a wire. Connect (or replace with a new piece of wire) the wire you disconnected from the volume control to one side of the SPDT switch, and connect the remaining switch terminal to the phono jack. Coonnect the ground side of the jack to the low side of the volume control. Use the switch to connect to phono or radio.
: : : : : ![]() : : : : : : : : : :Sir John. . . . : : : : :I saw this just sitting there previously, and wasn't sure WHUT that model # was. . .an AA-5 miniature tubed radio with an internal PCB used in its construction and also built as a clock radio. . .or. . .a Quasar TV. . .or. . . or some verrry old Motorola radio unit ? : :BUT. . . . before Sir Lewis also wires a telephone jack in, I'll additionally throw this illustration in below. : : :Back in the VEWY first of my collegiate days , the small 45 rpm player had just came out and it was ALSO offered as a bare bones unit , with only the shielded lead of the cartridge output to a male RCA plug, so that an additional console would let people upgrade a console to accomodate the new record type. : : :My CASH cow, was installing a phono input jack on smaller table radios in order to use its audio amp section and speaker(s). : :My Radio-Phono switching manner was merely to place a very minute burr on a rotor vane of the tuning condensers oscillator section when it was fully meshed. Run the tuning condenser to max meshed position at 550 and the radio was silenced. . . .BUT. . .usually, just a tuning off from receiving any station sufficed. . . .unless you were in one very "statticcy" environment !. . . arc welding etc. . . : : : : : :73's de Edd : : : ![]() : : : : |
