many thanks JIM
Here is the schematic: http://www.transoceanic.nostalgiaair.org/h-500.htm I don't see the box or polygon. Can you help us locate them?
Does the set work properly on the shortwave bands? If so, and from what you describe, everything would point to the BC switch. contacts.
Doug
:Hi guys I need some help on this problem.
:First I'm not that knowledgeable and pretty frustrated.
:the problem is that when I press the bcb switch part way in there is reception and when it's all the way in the signal strength drops significantly especially from 800 to 550kc.note I am using a 1r5 in place of 1l6.
:Also the sets been recapped and I gave the switch assy a good clean and sprayed with deoxit.
:I was looking at the schematic fig 16 of the military manual which shows the bcb circuit but don't know what the box symbol is as opposed to that other polygonal one.
:I don't have a 1l6 so I'm not sure if this is due to the 1r5, if it is this issue may be mute.
:Any advice?
:many thanks JIM
I would think that "S1A" would mean SWitch 1, section A.
http://www.transoceanic.nostalgiaair.org/index.htm#h500
hi doug
on the above link check the mil manual for r-520 then see figure 16. the notation for the switch is at the bottom of the figure "SIA BC" not sure what the SIA means.
The set works but just barely on the upper band which is expected with the 1r5
That 209-page Army tech manual for a T/O is something else. I'd love to know how much the government paid Zenith to develop that manual! Yikes.
I wonder what the U.S. Army used T/Os for in the 1950s (the date on the tech manual). I can only think of morale radios. If they were passed out to the troops, how many of them were ever turned back in?
Doug
:hi doug
:on the above link check the mil manual for r-520 then see figure 16. the notation for the switch is at the bottom of the figure "SIA BC" not sure what the SIA means.
:The set works but just barely on the upper band which is expected with the 1r5
Thanks Joe and everyone I'll try to get a better look at the contacts and recheck the wavemagnet.
I'll post again any follow up.
thanks to all
JIM
Does that model have a selenium rectifier? My T/O (L series) would work on some BC stations and fade out completely on others after a minute or two. The voltages were a little low after a check. The SW seemed to work fine at that time also.
I changed the rectifier with a diode and dropping resistor and it works fine now.
Could that be your problem?
Best Regards,
Bill Grimm
Another thing. Since you are using a 1R5 instead of the infamous 1L6, you may have to remove pin 5 of the 1R5. Pins 1 and 5 of the 1R5 are tied together internally. Not so in the 1L6. With the connection of 1 and 5 being made by the 1R5, may be upsetting the bias on the tubes. The bias circuit is quite elaborate in a TO. I have a Zenith AM only radio that had a bad 1L6 so I used a 1R5 but had to remove pin 5 to get it to work properly. If you do remove pin 5 from a 1R5, I might suggest using a Dremel tool with a cutoff disk instead of cutter pliars as the pliars may crack the tube base.
:Any advice?
:many thanks JIM
