:I'm presently working on a battery set (R414 see other posting for Stewart Warner Brigadier II). Filament A voltage is always low on cold start up (about 1.7 volts). after some fiddling with the variable capacitor it pops up to 2 volts. Would this problem be in the volume control?
Tubes in this radio are filament type. They will come up to operating within seconds. Could you have a bad bsttery connection? Is battery voltage low? There is a resistor in series with the "A" battery. Could it be high in value. Does it happen when the switch across the resistor is closed?
Variable capacitor should have no effect in filament voltage unless there is a bad battery connection. Then any movement may cause filament voltage to change.
:Hi
: Tubes in this radio are filament type. They will come up to operating within seconds. Could you have a bad bsttery connection? Is battery voltage low? There is a resistor in series with the "A" battery. Could it be high in value. Does it happen when the switch across the resistor is closed?
: Variable capacitor should have no effect in filament voltage unless there is a bad battery connection. Then any movement may cause filament voltage to change.
::I'm presently working on a battery set (R414 see other posting for Stewart Warner Brigadier II). Filament A voltage is always low on cold start up (about 1.7 volts). after some fiddling with the variable capacitor it pops up to 2 volts. Would this problem be in the volume control?
TABLE BORDER=1 CELLPADDING=10>
