Someone with the same tester or Alan Douglas may be able to help with the exact settings. If tube #26 is listed set up your 01A's the same way but with the filament at 5 volts.
: Hi,
: I'm trying to test a UX-201A tube and CX-301A tube on my Superior TW-11 Tube Tester. I can't find either
: tube (or any 01A) listed on the Roll Chart. Can anyone help me find what test settings I should select or what
: the tube may be called on the Roll Chart. The settings would probably be the same as on the more popular
: TV-11 tester
: Thanks,
: Craig
: Craig
: Someone with the same tester or Alan Douglas may be able to help with the exact settings. If tube #26 is listed set up your 01A's the same way but with the filament at 5 volts.
: Norm
: : Hi,
: : I'm trying to test a UX-201A tube and CX-301A tube on my Superior TW-11 Tube Tester. I can't find either
: : tube (or any 01A) listed on the Roll Chart. Can anyone help me find what test settings I should select or what
: : the tube may be called on the Roll Chart. The settings would probably be the same as on the more popular
: : TV-11 tester
: : Thanks,
: : Craig
Non of those. The UX201A is similar to a #26 except for filament voltage. That's a 26 without the letters. It has a 1.5 volt filament. Your tube tester may not have test setups for any old type tubes. Can you test 4 pin tubes? Are there settings for any 4 pin tubes?
: Norm, There are about 5 variations of a #26 tube listed (26A6, 26A7, 26BK6, 26C6, 26D6, 26Z5W, etc.), but all have a 25 filament voltage. I'm not sure if any of those are for a UX-201A or similar tube. I bet the setting will be the same as on any of the old Superior tube testers if someone out there has one.
: Thanks,
: Craig
: : Craig
: : Someone with the same tester or Alan Douglas may be able to help with the exact settings. If tube #26 is listed set up your 01A's the same way but with the filament at 5 volts.
: : Norm
: : : Hi,
: : : I'm trying to test a UX-201A tube and CX-301A tube on my Superior TW-11 Tube Tester. I can't find either
: : : tube (or any 01A) listed on the Roll Chart. Can anyone help me find what test settings I should select or what
: : : the tube may be called on the Roll Chart. The settings would probably be the same as on the more popular
: : : TV-11 tester
: : : Thanks,
: : : Craig
: Craig
: Non of those. The UX201A is similar to a #26 except for filament voltage. That's a 26 without the letters. It has a 1.5 volt filament. Your tube tester may not have test setups for any old type tubes. Can you test 4 pin tubes? Are there settings for any 4 pin tubes?
: Norm
: : Norm, There are about 5 variations of a #26 tube listed (26A6, 26A7, 26BK6, 26C6, 26D6, 26Z5W, etc.), but all have a 25 filament voltage. I'm not sure if any of those are for a UX-201A or similar tube. I bet the setting will be the same as on any of the old Superior tube testers if someone out there has one.
: : Thanks,
: : Craig
: : : Craig
: : : Someone with the same tester or Alan Douglas may be able to help with the exact settings. If tube #26 is listed set up your 01A's the same way but with the filament at 5 volts.
: : : Norm
: : : : Hi,
: : : : I'm trying to test a UX-201A tube and CX-301A tube on my Superior TW-11 Tube Tester. I can't find either
: : : : tube (or any 01A) listed on the Roll Chart. Can anyone help me find what test settings I should select or what
: : : : the tube may be called on the Roll Chart. The settings would probably be the same as on the more popular
: : : : TV-11 tester
: : : : Thanks,
: : : : Craig
