6/23/2009 8:22:33 PMJesse Hancock(75235:0)
Can someone Help me Im stumped.Ive replaced the electrolytics in several radios and never had the problems Im having now. I really am getting mad, I want to see this radio work,BUT Im unsure even after looking at the schmatic, where the rectifier tube is?
I see rect, noted in a part of the schematic, but its noted as a selenium rectfier? Im hoping that all the wires are hooked up correct.. Im really stumped. Can anyone help??? Will be willing to talk via phone if someone can email me with their number.. Or I can send mine..
6/23/2009 9:26:42 PMEdd(75239:75235)
Sir Jesse. . . .
Indeed your set does use a selenium rectifier that is being designated as X1 on your schematic, placed at almost the
extreme right bottom corner. Physically, on the set chassis, it is located at its OUTSIDE front of that chassis.
Sort of iffy as whether to use the set as it is, with that SR, or to replace it with an 1N4007 silicon diode, if so pull the selenium from circuit and change the R31 surge resistor upwards to an ~ 47-68 ohm value unit in order to enact a greater voltage drop. . . .thus ending up with the approximate voltage that the selenium rectum-fire was producing. The diode inherently has less of a voltage loss thru it than the selenium rect had.
Additionally, place an ~ .001-.0047@ 500-1kv rated ceramic capacitor across the 1N4007 diode, should a diode be used.
Assuredly, by now, you have ye olde filamentus lineamas restored now. . . .right ?
