Thanks Mike
Hey Mike - 38107 is .25 at 200 volt 38121 ? is .10 at 400 volt - the other numbers are unfamiliar to me. Give me the chassis number and trace the connection back to another component or two and I'll see if I can figure it out.
Steve
- I've pieced my info together from servicing a lot of Rogers ,Deforest Crosley and Majestic radios over the years. Unlike the RCC schematics - the Original Rogers service manual has parts lists that show the part numbers - Ed Kraushar has scanned Rogers volume 3 and its available by purchasing his CD's - along with a lot of other good information. (volume 3 covers 1937 to 1942 - if you have a 6m531 or 6d531 etc. its from 1936 - but the later years used Autolite caps too - and you can find the values by looking at the parts lists in that manual - sometimes you might have to check the schematic as well - for instance the parts list might say c22 38107 - but no value - then you have to find c22 on the schematic - and beside the c22 it will give the value - say .25 - no voltage in that case - but if in doubt use a 630 volt - they're not that much more expensive these days.
Steve
Steve
Thanks for the info. I am going to go though some other diagrams and see if I can make up a list of some of the other values. If I can put anything together I will try and post. I know what you mean I had another radio I had to trace the wires to figure out values. I was just hoping for an easier way.
Mike
