A model number would help locate the schematic.... Likely it needs to be recapped (ie., all the old capacitors ("caps") replaced). When capacitors that are used to filter the power supply go bad - it can result in a loud, over-powering hum. Also, if the wires to the antenna were not hooked back up correctly - this can result in a hum and distortion. But, again, knowing the specific model may be helpful in coming up with other repair hints and suggestions for you.
PS - please make sure you enter a topic
in the subject line of a new post. Most people here will ignore posts without a subject line....
OK, a few things we can check without a schematic. What does the hum do when you change the volume control? Does tuning the radio across stations affect the hum?
If you read the text ("General Description") on the schematic, you'll see that the wires in the lid are probably the loop antenna which was purposefully built into the lid. Unfortunately, the schemtic notes reveal that your radio has the type of IF coils that are prone to silver mica migration. That condition, if present, can lead to seriously loud static. That is not an impossible fix - but would likely be difficult for a beginner.
So, post a few clear pictures and let's go from there....
OK I take some
:So, post a few clear pictures and let's go from there....
