The Zenith 5A01 chassis is in Sam's Photofact #386. You may be able to get this through your local library or call Sam's at 800-428-7267.
norm
: Hi. I am looking for a schematic for a Zenith A513-R. The chasis type is 5A01. It must be a "newer" tube type because it actually has a printed circuit board, not point-to-point wiring. I would appreciate any help I can get locating a schematic. I have a rather bothersome intermittent problem. Probably due to the old circuit board flexing.
: Hi Larry
: The Zenith 5A01 chassis is in Sam's Photofact #386. You may be able to get this through your local library or call Sam's at 800-428-7267.
: norm
: : Hi. I am looking for a schematic for a Zenith A513-R. The chasis type is 5A01. It must be a "newer" tube type because it actually has a printed circuit board, not point-to-point wiring. I would appreciate any help I can get locating a schematic. I have a rather bothersome intermittent problem. Probably due to the old circuit board flexing.
