ak 55 c
6/14/2009 9:11:28 PMpaul
hi. i replaced the audio interstage transformer with a known good one. the volume is still the same. if i turn the volume up to max the stations diappear. im stumped. any ideas welcome. thank you paul.
6/15/2009 10:46:00 AMDoug Criner
Audio interstage xfmrs are usually either good or bad (with an open winding). If bad, you would get no audio at all.
As Norm suggested, measure the voltages at all the tube pins. Compare to specs: http://www.atwaterkent.info/TechData/Drawings/Images/AK14900sch.pdf
Or, report back here with all the voltages.
Doug
6/20/2009 10:52:58 PMpaul
hi doug thank you for the info. doing voltage test is better than replacing ervery part under the sun. thank you paul w.
6/21/2009 1:08:43 PMphil
hi,don't forget about the local/distant switch,corrosion here will cut out the first tube reducing volume greatly.
:hi doug thank you for the info. doing voltage test is better than replacing ervery part under the sun. thank you paul w.
6/22/2009 1:33:00 AMLou
Also, you need a good antenna, connected to the proper binding post.
AND, you need to ensure that the tuning of the unit is on track. If you are losing tracking between capacitors, you will lose a LOT of volume.
Lou
:hi,don't forget about the local/distant switch,corrosion here will cut out the first tube reducing volume greatly.
::hi doug thank you for the info. doing voltage test is better than replacing ervery part under the sun. thank you paul w.
