6/12/2009 11:36:55 PMCHRIS(74876:0)
Hello all.I just got my first late 1920's early 1930's highboy.It is a Canadian Deforest-Crosley .I can't find the model number.It is sort of a mini highboy with a single ended 45 output and 3 24A's.The thing is someone at some time changed the #45 to a #47 socket and all.It says 45 on the transformer can.Why would this have been done.Could you get more power from the 47 (screen grid).Would this be hard on the #47 because the load impedance is different than a 45 or could the screen grid not be connected?I would like to put it back to original design when I overhaul(change capacitors etc.)Any info would be appreciated.Thanks
6/13/2009 7:39:04 AMJim l(74877:74876)
Chris. Heres one reason that comes to mind why someone would change socket so they ould use 47 instead 45 tube.. Its what they had on hand. Like needing a good 45 but not have it but plenty of 47 type. I have done that lately myself so as not to invest too much in a radio I was going to sell anyway.
6/13/2009 2:14:32 PMWarren(74882:74876)
Some time in the past someone may have done that to make the radio performance better. Or may have thought so.
A lot of old radios have had many owners, and have been modified in one way or another. Sometimes it's a make do with the parts they had on hand. It would be up to you if the past work done was a good idea or not. Makes this hobby a little more interesting.
6/13/2009 11:34:23 PMCHRIS(74894:74882)
:Some time in the past someone may have done that to make the radio performance better. Or may have thought so.
:A lot of old radios have had many owners, and have been modified in one way or another. Sometimes it's a make do with the parts they had on hand. It would be up to you if the past work done was a good idea or not. Makes this hobby a little more interesting. Thankyou both for the information!
