Loud staticy hum when television connected to stereo
6/10/2009 2:25:28 AMCHRIS
Hello all.I have a 1960's Silvertone Custom Stereophonic receiver that uses 4 6BQ5's and has a separate power supply chassis and radio chassis.I have my television DVD and VCR hooked into the inputs.Sounds absolutely amazing watching movies through!!However when I switch it to radio there is aloud static hum sound.It totally disappears when I pull the RCA plugs out from the television.What is this all about.Not a big deal to plug and unplug jacks, but can anything be done to eliminate this?Is this some kind of grounding issue??Any info would be appreciated.Thanks
6/11/2009 9:47:40 AM!-
:Hello all.I have a 1960's Silvertone Custom Stereophonic receiver that uses 4 6BQ5's and has a separate power supply chassis and radio chassis.I have my television DVD and VCR hooked into the inputs.Sounds absolutely amazing watching movies through!!However when I switch it to radio there is aloud static hum sound.It totally disappears when I pull the RCA plugs out from the television.What is this all about.Not a big deal to plug and unplug jacks, but can anything be done to eliminate this?Is this some kind of grounding issue??Any info would be appreciated.Thanks
6/11/2009 12:31:45 PMWarren
It could be the cables are to close to AC cords, and other cable junk. If you have kind of a mess of cables and wires, try running the cables as short and direct as you can. Even try another AC outlet for the radio, not all on like a plug strip.
6/13/2009 11:36:42 PMCHRIS
:It could be the cables are to close to AC cords, and other cable junk. If you have kind of a mess of cables and wires, try running the cables as short and direct as you can. Even try another AC outlet for the radio, not all on like a plug strip. Thankyou Warren.I will try these ideas.
