I have a Grundig 8058 and I have identified all the tubes but 2. Can someone tell me the tube type for Grundig part # 340 and # 331.
Also, did they share the same chassis among several models? It might help me find a schematic.
Thanks, Rob
look into your mailbox ;-) - i have sent you the schematic.
Best regards Walter Haring
http://www.samswebsite.com/
Yes, the chassis was used 8068, 8095, and 8098.
The part numbers are of use only in reference to that model line. If youhave the european tube numbers, cross matching is easy. If it is a matter of tubes missing, the Photofact is going to be most reliable, even though they do charge for them. Sometimes your public library may have them.
: Hello,
: I have a Grundig 8058 and I have identified all the tubes but 2. Can someone tell me the tube type for Grundig part # 340 and # 331.
: Also, did they share the same chassis among several models? It might help me find a schematic.
: Thanks, Rob
