You can check filaments between two large pins on each tube. After you are ready measure tube pin voltages. This will give an idea how well tubes are operating. In most cases tubes will be usable.
:Greetings everyone,
:I found this old radio (Philco 54), a real bomb, as fate would have it it is time to take the next step. I do not have slots in my tube tester to test the tubes in that radio. Soooooooo, can anyone direct me to some literature of tube testing with a multimeter or help in any way. I can test easily to check the filaments and that's it. So, filament efficiency and gassy tubes are the issue.
:Thank you,
:Vinny A.
Gassy tubes are not likely to be an issue. By "filament efficiency," you are likely referring to cathode emission? That will seldom keep a set from working.
This is an AC/DC set. You can bring it up, preferably on a variac if you have one, and see if the tubes light up. If so, you can figure the tubes are OK. If the set doesn't work even though the tubes light up, then I would troubleshoot in a systematic manner before wholesale replacement of caps or other components.
If the tubes don't light up, then likely one of them has a open filament.
Doug
::I found this old radio (Philco 54), a real bomb, as fate would have it it is time to take the next step. I do not have slots in my tube tester to test the tubes in that radio. Soooooooo, can anyone direct me to some literature of tube testing with a multimeter or help in any way. I can test easily to check the filaments and that's it. So, filament efficiency and gassy tubes are the issue.
::Thank you,
::Vinny A.
:Can't add too much to Norm's suggestions.
:Gassy tubes are not likely to be an issue. By "filament efficiency," you are likely referring to cathode emission? That will seldom keep a set from working.
:This is an AC/DC set. You can bring it up, preferably on a variac if you have one, and see if the tubes light up. If so, you can figure the tubes are OK. If the set doesn't work even though the tubes light up, then I would troubleshoot in a systematic manner before wholesale replacement of caps or other components.
:If the tubes don't light up, then likely one of them has a open filament.
:Doug
:::I found this old radio (Philco 54), a real bomb, as fate would have it it is time to take the next step. I do not have slots in my tube tester to test the tubes in that radio. Soooooooo, can anyone direct me to some literature of tube testing with a multimeter or help in any way. I can test easily to check the filaments and that's it. So, filament efficiency and gassy tubes are the issue.
:::Thank you,
:::Vinny A.
Vinny A.
:Vinny
: You can check filaments between two large pins on each tube. After you are ready measure tube pin voltages. This will give an idea how well tubes are operating. In most cases tubes will be usable.
::Greetings everyone,
::Thank you,
::Vinny A.
