:Greetings to all.
:I have a philco 48-200 with a 130 ohm 20% resistor off the output tube that is out of tolerance. My problem is that I am unable to locate a 130 ohm resistor. I do have a 120 and a 150 ohm resistor with a 5% tolerance.
:Is it better to go under with the 120 or over with the 150? Both fall within the 20% range error. The new resistors have a gold band.
:Thank you,
:Vinny A.
The 130 ohm resistor is in series with cathode of 50L6 output tube. There is 5 volts across the resistor and it dissipates .2 watts. If replaced use a 1 watt resistor. 1/2 watt will work but it will get warm.
You will not notice a difference replacing this resistor. A lower value will just cause the tube to operate hotter by reducing grid bias.
http://www.nostalgiaair.org/PagesByModel/627/M0013627.pdf
:Warren, thank you for your time and expertise in responding. I was also considering leaving well enough alone. The original resistor measured 165 ohms, well out of tolerance, however I will try the 120 and see.
:Thanks again,
:Vinny A.
:Hi Vinny
: The 130 ohm resistor is in series with cathode of 50L6 output tube. There is 5 volts across the resistor and it dissipates .2 watts. If replaced use a 1 watt resistor. 1/2 watt will work but it will get warm.
: You will not notice a difference replacing this resistor. A lower value will just cause the tube to operate hotter by reducing grid bias.
:http://www.nostalgiaair.org/PagesByModel/627/M0013627.pdf
::Warren, thank you for your time and expertise in responding. I was also considering leaving well enough alone. The original resistor measured 165 ohms, well out of tolerance, however I will try the 120 and see.
::Thanks again,
::Vinny A.
