Bounce & Lens Dust
5/29/2009 1:01:38 AMGeorge T
Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
5/30/2009 12:08:09 AMMarv Nuce
Geo,
Yea, it works. Been doing on my TV's (crts only) for years, but of course being a smoker, takes more effort to clean that stuff off.
:Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
5/30/2009 12:36:18 AMGeorge T
:Hi Marv, The wife and I smoke she just found out that dish soap (Dawn) on a damp rag to clean the screen, then wipe off with clear water on a damp rag works great to clean the TV screen much better than Windex. Will try the Bounce on the screen, living in the middle of a desert we get dust everywere. Heck I might try Bounce on a couple radios and see if it cuts down the dust. Thanks for the info.
:Geo,
:Yea, it works. Been doing on my TV's (crts only) for years, but of course being a smoker, takes more effort to clean that stuff off.
:marv
::Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
5/30/2009 8:19:20 AMsmoking kills and is expensive
::Hi Marv, The wife and I smoke she just found out that dish soap (Dawn) on a damp rag to clean the screen, then wipe off with clear water on a damp rag works great to clean the TV screen much better than Windex. Will try the Bounce on the screen, living in the middle of a desert we get dust everywere. Heck I might try Bounce on a couple radios and see if it cuts down the dust. Thanks for the info.
::Geo,
::Yea, it works. Been doing on my TV's (crts only) for years, but of course being a smoker, takes more effort to clean that stuff off.
::marv
:::Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
5/30/2009 1:56:31 PMMarv Nuce
Yea right Bubba, but you ain't buyin mine, so pipe down. Talk is cheap.
:::Hi Marv, The wife and I smoke she just found out that dish soap (Dawn) on a damp rag to clean the screen, then wipe off with clear water on a damp rag works great to clean the TV screen much better than Windex. Will try the Bounce on the screen, living in the middle of a desert we get dust everywere. Heck I might try Bounce on a couple radios and see if it cuts down the dust. Thanks for the info.
:::Geo,
:::Yea, it works. Been doing on my TV's (crts only) for years, but of course being a smoker, takes more effort to clean that stuff off.
:::marv
::::Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
5/30/2009 3:25:12 PMGeorge T
:If one thing don't kill ya the other surely will.
:Yea right Bubba, but you ain't buyin mine, so pipe down. Talk is cheap.
:marv
::::Hi Marv, The wife and I smoke she just found out that dish soap (Dawn) on a damp rag to clean the screen, then wipe off with clear water on a damp rag works great to clean the TV screen much better than Windex. Will try the Bounce on the screen, living in the middle of a desert we get dust everywere. Heck I might try Bounce on a couple radios and see if it cuts down the dust. Thanks for the info.
::::Geo,
::::Yea, it works. Been doing on my TV's (crts only) for years, but of course being a smoker, takes more effort to clean that stuff off.
::::marv
:::::Just a little trick. You know when you make a replacement lens it has a habit of collecting dust. So you have to remove the chassis and clean the dust from inside the lens. Well before you put the chassis in borrow a sheet of Bounce from the wife and lightly wipe the lens and it will remove the static electricity and it won't collect dust. It works GREAT.
