Does anyone have any suggestions for cleaning the celluloid dials that were prevalent in the 30's as Philco and AK? Dont want to use anything that would remove the ink. I"ve seen many sets that a previous owner became overzealous with.
i think someone in the antique radio forum mentioned mineral spirits but you could check to be sure. water removed the ink but the mineral spirits did not if i recall
::Hello All,
:: Does anyone have any suggestions for cleaning the celluloid dials that were prevalent in the 30's as Philco and AK? Dont want to use anything that would remove the ink. I"ve seen many sets that a previous owner became overzealous with.
:i think someone in the antique radio forum mentioned mineral spirits but you could check to be sure. water removed the ink but the mineral spirits did not if i recall
As have others here I have ruined several dials in cleaning them. I now just use warm water and Q-tips to very carefully clean as best as I can, staying away from the letters as much as I can. If it does not get clean, Oh well, its just part of the radios charachter earned through the years.
Jon.
I actually tried Fantastik cleaning spray once - what a disaster!!!
Lou
:Hello All,
:As have others here I have ruined several dials in cleaning them. I now just use warm water and Q-tips to very carefully clean as best as I can, staying away from the letters as much as I can. If it does not get clean, Oh well, its just part of the radios charachter earned through the years.
:Jon.
:Hello All,
Dust the dial but don't use anything, water or cleaning solvent, until you know it's safe. Even a damp cloth can remove the marking.
If you want to try water use it in a corner first where missing markings won't be seen.
:Hello All,
Thanks for the advice and suggestions. I certainly will proceed with caution if at all.
:Hi Bill
: Dust the dial but don't use anything, water or cleaning solvent, until you know it's safe. Even a damp cloth can remove the marking.
: If you want to try water use it in a corner first where missing markings won't be seen.
::Hello All,
