Philco model 19 run 126 tone control
5/25/2009 2:38:16 AMG. Berg
I have a philco 19 run 126 chassie and can not find info for tone control.....anyone know this info ?
5/25/2009 8:19:16 AMNorm Leal
Hi
Tone control is two .015 mf caps in series from output tube plate to B-. The tone control switch shorts across one.
Is your circuit different?
http://www.nostalgiaair.org/PagesByModel/151/M0013151.pdf
Rev 126 differences are shown here:
http://www.nostalgiaair.org/PagesByModel/152/M0013152.pdf
:I have a philco 19 run 126 chassie and can not find info for tone control.....anyone know this info ?
5/25/2009 2:34:39 PMG. Berg
Got it THANKS!!!:
Hi
: Tone control is two .015 mf caps in series from output tube plate to B-. The tone control switch shorts across one.
: Is your circuit different?
:http://www.nostalgiaair.org/PagesByModel/151/M0013151.pdf
: Rev 126 differences are shown here:
:http://www.nostalgiaair.org/PagesByModel/152/M0013152.pdf
::I have a philco 19 run 126 chassie and can not find info for tone control.....anyone know this info ?
5/26/2009 1:51:08 AMG. Berg ...NORM....info not correct
:Norm..and all others...On the Philco 19 run 126 series the tone control is different than 2 .015 caps in series. I took the tone control apart (picked tar out) and there apears to be 1 .015 cap and the other one is about 1/4 in size. I used a .02 and a .01 caps as replacement..will fire this up tomorrow and see how it works. ( I recapped the entire set..and more) OHHH I just love picking out the old tar out of the cans that Philco used...HA HA Actually I do..kind-a relaxing....
5/26/2009 10:21:56 AMNorm Leal
Hi
I mentioned what was shown in Rider. Different value caps can be used. Select ones that give the best tone response to your ears. Different values will not hurt the circuit.
::Norm..and all others...On the Philco 19 run 126 series the tone control is different than 2 .015 caps in series. I took the tone control apart (picked tar out) and there apears to be 1 .015 cap and the other one is about 1/4 in size. I used a .02 and a .01 caps as replacement..will fire this up tomorrow and see how it works. ( I recapped the entire set..and more) OHHH I just love picking out the old tar out of the cans that Philco used...HA HA Actually I do..kind-a relaxing....
:: Tone control is two .015 mf caps in series from output tube plate to B-. The tone control switch shorts across one.
:: Is your circuit different?
::http://www.nostalgiaair.org/PagesByModel/151/M0013151.pdf
:: Rev 126 differences are shown here:
::http://www.nostalgiaair.org/PagesByModel/152/M0013152.pdf
:::I have a philco 19 run 126 chassie and can not find info for tone control.....anyone know this info ?
5/26/2009 6:08:55 PMg berg
Sounds good ...
: I mentioned what was shown in Rider. Different value caps can be used. Select ones that give the best tone response to your ears. Different values will not hurt the circuit.
:::Norm..and all others...On the Philco 19 run 126 series the tone control is different than 2 .015 caps in series. I took the tone control apart (picked tar out) and there apears to be 1 .015 cap and the other one is about 1/4 in size. I used a .02 and a .01 caps as replacement..will fire this up tomorrow and see how it works. ( I recapped the entire set..and more) OHHH I just love picking out the old tar out of the cans that Philco used...HA HA Actually I do..kind-a relaxing....
::: Tone control is two .015 mf caps in series from output tube plate to B-. The tone control switch shorts across one.
::: Is your circuit different?
:::http://www.nostalgiaair.org/PagesByModel/151/M0013151.pdf
::: Rev 126 differences are shown here:
:::http://www.nostalgiaair.org/PagesByModel/152/M0013152.pdf
::::I have a philco 19 run 126 chassie and can not find info for tone control.....anyone know this info ?
