Need A Transformer
5/23/2009 1:54:59 AMJohnny
Okay folks this is a little off base as far as radios but I use this thing to work on my radios on a daily basis. Does that help I hope. I'm desperate. I've been all over the internet and can't find anything close.
This is a two wire transformer about the size of an audio xsfmr from our radios and it goes in the magnification lamp I use on my work bench. Light quit working so I put a new 8" diameter bulb in it. 22 watt. Still doesn't work. I put a new starter in it. Still doesn't work. Only thing left is this transformer. I do have 120vac at the bulb connector and 10vac on the other 2 pins at the connector.
I can give you all the numbers off of it but they don't seem to be doing me any good as far as searching for a replacement. I see 22 ohms across the two white wires coming out of the transformer in either direction I read them. It is a 120 volt, 60Hz, 0.38 amp. Says right on it.
Does anyone have any ideas on this? Sure would be appreciated. It's either fix it or trash it and it cost me about 80 bucks four years ago.
Johnny
5/23/2009 2:09:59 AMJohnny
:Okay folks this is a little off base as far as radios but I use this thing to work on my radios on a daily basis. Does that help I hope. I'm desperate. I've been all over the internet and can't find anything close.
:This is a two wire transformer about the size of an audio xsfmr from our radios and it goes in the magnification lamp I use on my work bench. Light quit working so I put a new 8" diameter bulb in it. 22 watt. Still doesn't work. I put a new starter in it. Still doesn't work. Only thing left is this transformer. I do have 120vac at the bulb connector and 10vac on the other 2 pins at the connector.
:I can give you all the numbers off of it but they don't seem to be doing me any good as far as searching for a replacement. I see 22 ohms across the two white wires coming out of the transformer in either direction I read them. It is a 120 volt, 60Hz, 0.38 amp. Says right on it.
:Does anyone have any ideas on this? Sure would be appreciated. It's either fix it or trash it and it cost me about 80 bucks four years ago.
:Thanks,
:Johnny
Just a little more info. 120vac cord coming in. Black wire goes directly to lamp. White wire goes to one leg of transformer. Other white wire on transformer goes to lamp. Green wire is ground. So I guess you could say the transformer is in series with the white neutral/return of the 120vac line. Starter is at the lamp somewhere. What is this transformer doing?
5/23/2009 2:41:28 AMWarren
I think what you have there is an older pre-heat fixture.
The two wire thing is a ballast transformer. If you are reading 22 ohms across it, I think it's still good. Might check the on off switch itself, or bad connections where the starter is. Might be able to get a Kitchen round florescent fixture and use the rapid start gut and bulb if you can find one 8 inch.
5/23/2009 11:08:24 AMEdd
O.K. Here is more than enough info, such that you should now be able to trace your problem on that unit,
It possibly ? being a Luxo or Magna Lux unit with a Circline lamp surrounding a geee-iant magnifier lens mounted in the center.
Take an ohmmeter and place one lead on the [BLACK], HOT, AC line at the plug and then use the other ohmmeter lead to make your first check past the switch and flip to see if the switch is working O.K.
Then test on past the ballast, which you already confirm as having continuity and about the proper resistance already.
The next point would be to either pull the tubes white 4 pin side connector and measure the tubes 4 connections to see if you have two sets of continuity betwen the two pre-heat filaments that the diagram shows. OR, you could check at the socketry, for continuity thru that [A] pre heat filament ,if easy enough to get access to, or else use needle tips to pierce the wire insulation, or at least, those finer points may reach up into the socketry better.
Next side track over to the other prong of the AC plug and check for continuity between that point up to the [B] pre-heat filament in the tube.
If you have continuity thru those two loops, its logical that the unit might have fault with the starter unit or the wrong wattage of starter is being used.
One can eliminate the starter question by getting it where you can unplug the starter and place a jumper clip [BLUE] across one of its sockets terminals, plug in the lamp unit and enact a short connection between the starter socket for about a 5 count, where you should see a weak orange glow inside the lamp and then when the shorting connection is broken the unit should then fire-ionize between the the lamps internal electrodes- and light up.
If not then I would suspect the lamp, particularly if it is 22 years old and has darkened / black / gray ion burns on the white phospor areas near its pre heat filament electrodes.
If you are using the "shorting across of the starter" technique, here is what is happening;
The power comes in and hits the ballast which is performing two tasks, initially it is presenting such a restrictive AC impedance to the incoming 60~ AC power that it is functioning like a heavy power resistor in the manner of precisely current limiting the amount of power that will be able to be consumed in that closed lamp loop circuitry path.
If you will then track the red arrow path, starting at the HOT wire,you will see that it initially gets thru the switch allright and then gets as far as the [A] filament where is sees that there is no place to go across that wi i i ide [A] --[B] chasm there, so it flows on thru the [A] filament down thru the [GOLD] arrow path and ends up at the starter, inside that starter we find it to be akin to a glorified NE-2 lamp with an addition of argon gas and a trace strontium 90 ionization enhancer, along with two hefty internal electrodes, and in between the two is a bimetallic strip that is spot welded to one and almost makes contact to the other electrode.
All we need to do now is look across to the opposite electrode and see that it has continuity to the other side of the AC line. . . . .so we have a potential working neon lamp circuit now, since the voltage IS above ~65 VAC, the gas ionizes and fires and we have a working lamp, but being hopped up quite a bit from your normal neon, so much in fact, that the heat of that ionized gas path additionally rapidly heats up the bimetallic strip and it stretches over and shorts across the starters electrodes.
Well, that then completes a path with AC power thru the ballast and the two pre heater filaments of the tubes with the then limited power that the ballast is letting thru, But wait, lets look back to that starter internals where you had the short betwen the electrodes by the heated and then flexed bi metallic stip, well, with those electrodes being shorted across, there is no longer any heat being produced by the ionized gas path across the electrodes.
Sooooooo the now cooled down strip comes un-flexed and opens its shorting action. That action produces yet another effect , the opening of the complete circuit loop thru the ballast and the lamps two filaments. . . .AND the most important effect is that abrupt disruption of power caused one of the healthy AC fields being developed within the ballast to collapse and develop a multi hundred volt back EMF spike.
Since it is swinging thru 60 positive and negative nodes per second, the odds are good that the timing is such that the disruption will be at a peak voltage level or well enough on up the voltage curve, to produce one HEALTHY spike.
Now if you remember when that lower AC voltage ran across that A-B filament path , it initially ignored that cold tube,and went down the [GOLD] arrow path, but now, with that initial pre-warm up of the filaments PLUS there also being 120 VAC. . . ACROSS. . . the tube electodes to boot, all it now takes is that high voltage spike to initially ionize a path across [A]-[B] electrodes and THEN the current limited 120VAC supply will travel across that just created plasma path.
With that happening, you can then say. . .And let there be light !
Meanwhile . .back in the jungle. . .errrr. . .down at the starter unit , with that new conductive circuit path having been made across the fluorescent tubes [A]-[B]electrodes and it also shunting the starter, that starter no longer has the voltage presence to ionize its gas, so it just remains dormant and out of circuit until power down and cool down of the main lamp.
Remember when I mentioned the ballast having to be on or almost to a peak + or - node when the starter opened up, sometimes that might occur at zero crossover, and in which case, the starter cycles and tries again. . .(and again.)
Manual Start:
If you are using a momentary push-button switch in place of the starter , you are needing it on just enough time to preheat the filament and then its opening action is creating the ionizing high voltage back EMF spike required to fire between the electrodes.
BUT seems like I would say that the FAILURE for a starter unit to initially start , is about the INVERSE odds that you sometimes experience on the turning on of an incandescent lamp, whereupon you flip it on JUST at the peak of an AC + or - voltage node and the lamp pops just like a flash bulb.
FLOURESCENT LAMP WIRING LAYOUT. . . . SCHEMATIC :
5/23/2009 11:37:39 AMA. . .denda
OH-MI-GOSH, I see that I forgot to additionally have you check all of that units .. .rather somewhat skimpy sized plastic dual conductor wiring, near all of its bends.
In the case of my unit, it mounts via a C –clamp with an imbedded cavity such that the accordion arms can be swiveled about.
I KNOW that for a fact, that mine gets such USE in its swiveling and pushing way back out of the way, that another consideration is multi transpositional wire flexure fatigue, with strands progressively breaking inside the insulation until there is a wiring continuity gap.
GREAT SHADES of Mamma Cass and her great ironing cord fiasco. . .it happening after just about 8 tousand 9 hunna and lebenteen flexures.
5/23/2009 2:24:13 PMJohnny
:OH-MI-GOSH, I see that I forgot to additionally have you check all of that units .. .rather somewhat skimpy sized plastic dual conductor wiring, near all of its bends.
:In the case of my unit, it mounts via a C –clamp with an imbedded cavity such that the accordion arms can be swiveled about.
:I KNOW that for a fact, that mine gets such USE in its swiveling and pushing way back out of the way, that another consideration is multi transpositional wire flexure fatigue, with strands progressively breaking inside the insulation until there is a wiring continuity gap.
:GREAT SHADES of Mamma Cass and her great ironing cord fiasco. . .it happening after just about 8 tousand 9 hunna and lebenteen flexures.
:Well I guess my troubleshooting skills are deminishing over the years. I had voltage at the bulb socket so I ignored the switch. OOPS!!! I checked the switch this morning after I saw your thread and walla. Bad switch. Good ol' radio shack just happened to have one that would fit the lamp housing with minimal modification. And it was said... Let there be light and there was light.
Thanks Edd,
Johnny
5/24/2009 1:24:30 AMPeter G. Balazsy
::Well I guess my troubleshooting skills are deminishing over the years. I had voltage at the bulb socket so I ignored the switch. OOPS!!! I checked the switch this morning after I saw your thread and walla. Bad switch. Good ol' radio shack just happened to have one that would fit the lamp housing with minimal modification. And it was said... Let there be light and there was light.
:Thanks Edd,:Johnny
Hi Johnny:
Picky picky I know... but "walla" = voilà !
Those damned French... they seem to have their own words for everything!!
5/24/2009 11:39:40 PMLewis L
:::Well I guess my troubleshooting skills are deminishing over the years. I had voltage at the bulb socket so I ignored the switch. OOPS!!! I checked the switch this morning after I saw your thread and walla. Bad switch. Good ol' radio shack just happened to have one that would fit the lamp housing with minimal modification. And it was said... Let there be light and there was light.
::Thanks Edd,:Johnny
:Hi Johnny:
:Picky picky I know... but "walla" = voilà !
:Those damned French... they seem to have their own words for everything!!
Hey. Watch it. My grandmothers' maiden names were LaFitte and Mouzon. Voila simply means "see there" Voici means "see here" {;>}~
P S Glad to hear you got your light fixed. At my age, I need all the help I can get to see.
Bon nuit.
