Graybar/RCA Chasis
5/19/2009 5:35:07 PMBruce Walters
I have a Graybar model 700 with four 224s, two 227s, two 245s and an 280 rect. I am 90% sure it is an RCA chasis, but I can't find a chasis number on it anywhere. The sound volume is too loud and I suspect a flakey resister and or one was incorrectly replaced, but i can't trouble shoot the beast without a schematic. Anyone know for sure it is an RCA and which chasis it might be?
5/19/2009 6:03:43 PMCarl T
:I have a Graybar model 700 with four 224s, two 227s, two 245s and an 280 rect. I am 90% sure it is an RCA chasis, but I can't find a chasis number on it anywhere. The sound volume is too loud and I suspect a flakey resister and or one was incorrectly replaced, but i can't trouble shoot the beast without a schematic. Anyone know for sure it is an RCA and which chasis it might be?
Bruce,
Take a look at the Radiola 80:
http://www.nostalgiaair.org/PagesByModel/342/M0040342.pdf
Carl T
5/19/2009 7:14:22 PMBruce W
::I have a Graybar model 700 with four 224s, two 227s, two 245s and an 280 rect. I am 90% sure it is an RCA chasis, but I can't find a chasis number on it anywhere. The sound volume is too loud and I suspect a flakey resister and or one was incorrectly replaced, but i can't trouble shoot the beast without a schematic. Anyone know for sure it is an RCA and which chasis it might be?
:Bruce,
:Take a look at the Radiola 80:
:http://www.nostalgiaair.org/PagesByModel/342/M0040342.pdf
:Carl T
Thanks Carl,
That sure looks right to me, I appreciate the help.
5/19/2009 7:36:32 PMEdd
Try this size 80-82-86 on, and see if it fits, or is at least close enough to work with .
RCA_Model’s 80-82-86. . . . . . SCHEMATIC :
5/20/2009 11:57:36 AMBruce W
You guys spoil me with such great knowledge. I felt really good about fixing this one last night. I turned the chasis over and there was one obvious repair that had been done. Someone relaced a resistor that was part of the voltage divider network that included the volume control. I measured the replaced resistor at 38K instead of 18K, then of course replaced it. BINGO! Funny how often the problems are a result of someone elses "repair".
:Try this size 80-82-86 on, and see if it fits, or is at least close enough to work with .
:RCA_Model’s 80-82-86. . . . . . SCHEMATIC :
