I did a bad thing and recapped all the capacitors at once, now I have an issue. Before the recap, I got static. After the recap, when I turn the voltage up slowly, the rectifying tube glows very brightly. I'm assuming it's getting too much voltage. I would suspect one of the electrolytic capacitors. Does anyone have a checklist of likely culprits? Could I have also damaged a resistor?
Any recommendations for old books that shows a novice how to diagnose though a step-by-step routine? Most of the books I have deal in theory, not in the practical.
Thanks!!
A model number would be helpful.
First I would double check the filter capacitors' polarity and shorts to groun. Also verify the voltage to the heaters/filaments.
Syl
Syl, Warren, Thanks! It is a model 48-200. I did reverse the electrolytic C's. I looked at the arrow and the negative mark, and made the conclusion that the arrow follows the flow of electricity. It doesn't, the negative side goes the the negative source.
I replaced the tube and the 3 E. Capacitors. The unit has static when I move the tuner, but there's no background static otherwise, so I need to check if I burned anything else out. Won't make that mistake next time.
Thanks!
