I just acquired a SX 25 but without the external speaker.
it has two speaker connections labeled 500 and 5000 ohms.
What would be a suitable substitute to the hallicrafters speaker?
:It would be nice just to go ahead and get the correct Hallicrafters speaker for that classic radio. Your radio has about 10 watts output. The Hallicrafters speaker has a big magnet, and the size for best sound. You could however replace the output transformer with like A Chicago Standard Transformer A-3839 . That one has taps for a 4 - 8 - 16 ohm speaker ..
It has so much audio drive, that it will work well into an 8 ohm speaker, believe it or not.
Lou
:Hi,
:I just acquired a SX 25 but without the external speaker.
:it has two speaker connections labeled 500 and 5000 ohms.
:What would be a suitable substitute to the hallicrafters speaker?
Mike M
:Yeah Lou, I too have used an 8 ohm speaker on those SX model Hallicarfters. However if you really turn it up and get it a little on the loud side, the poor old output transformer is working into what it looks to be a near short. Can warm it up a little with a 10 watt push pull driving it. With a real Hallicrafters speaker it does make a difference with the over all sound from High to Low. The speaker for an SX-25 has the same deco like trim to match the radio. Still a few around to be had, and makes that classic Hallicrafters more enjoyable.
:Right now I'm using an 8 ohm with a series 500 ohm resistor. Cuts down on the volume but is ok for now. I believe the speaker number is PM-23. Did not find any on ebay or google. If anyone has one they want to part with, my email is posted. Thanks for the help.
:Mike M
::Yeah Lou, I too have used an 8 ohm speaker on those SX model Hallicarfters. However if you really turn it up and get it a little on the loud side, the poor old output transformer is working into what it looks to be a near short. Can warm it up a little with a 10 watt push pull driving it. With a real Hallicrafters speaker it does make a difference with the over all sound from High to Low. The speaker for an SX-25 has the same deco like trim to match the radio. Still a few around to be had, and makes that classic Hallicrafters more enjoyable.
