Now on both AM and FM I have noticed that on very strong bass notes where that speaker cone really starts to move air...
I occasionally hear a crackle that seems coincident with the lowest bass notes or max movement of the cone. There also seems to be some rumbling "cone-oscillation"? is that it?.. whatever it is the bass starts to "rumble".. I know that can't be right.
I tried 3 or four similar sized cones older and newer and they all make the static-like crackle at the most bass sounds but some rumble more so than others.
The worst rumbling cone I treated with some flexible speaker cone treatment right at the outer edge folds.. and that seemed to reduce rumble quite a bit as it is more flexible now I think.
What causes the crackle? Something in the tubes? Arcing in the output transformer?
I tried changing them with some improvement but can't be positive.
I'm confused as to what exactly would cause static-like crackle, on deep bass only.
Peter, try increasing that .002 across the opt primary to a .02 or experiment with little higher values than the .002.
Bill
