ZENITH SS2341AR DIODES
2/8/2001 8:28:56 PMRobert
Good day,
I have a Zenith Model SS2341AR that was blowing the main fuse.. I found 2 shorted diodes in the power supply. The location numbers on the main board are
CR3274 and CR3272. The numbers on both diodes are
T-315-06. I have no schematic and I am not able to cross reference these diodes.. Are they rectifiers and if so what would be the NTE cross for these or what are there values.. I would appreciate help with the repair of this good old set..
Thank you in advance
Robert..
2/10/2001 1:07:53 PMJohn McPherson
Are the diodes connected to one side of the power transformer, or RC filter? If yes, they are rectifiers. Unless there are voltage sensitive IC's, or a need for an absolutely stable voltage reference- ie for a transmitter, those could be Zener diodes, but that would be the only complication.
NTE125, or NTE156 should be adequate replacements.
: Good day,
: I have a Zenith Model SS2341AR that was blowing the main fuse.. I found 2 shorted diodes in the power supply. The location numbers on the main board are
: CR3274 and CR3272. The numbers on both diodes are
: T-315-06. I have no schematic and I am not able to cross reference these diodes.. Are they rectifiers and if so what would be the NTE cross for these or what are there values.. I would appreciate help with the repair of this good old set..
: Thank you in advance
: Robert..
