It's detailed in their Auto Radio series book AR-33. I don't happen to have that volume but perhaps another forum member, or your public library, does.
Brian,
I would mail you a photocopy of the Bendix manual if you wish to email me your mailing address. There are 2 small electrolytic capacitors on the main circuit board that are known to be suspect. One; a 60mfd axial at 3 volts is located near the volume control; the other; a 50mfd radial at 3 volts is located inboard from the antenna socket.
These radios also use 5 PC component modules--good luck if one of them is bad. You would have to create the equivalent out of separate components.
Meade
:The SAMS Index lists a model# T0B5TBC. Not sure if this model would be close enough to yours (only the last letter is different).
:It's detailed in their Auto Radio series book AR-33. I don't happen to have that volume but perhaps another forum member, or your public library, does.
I just figured out how to get your email address Meade, you'll have mail shortly....Brian
Supplied herewith is that TOB5TBC info. With the most common need to be a pound of solder , a STROOOONG magnifying
