SHOCKS
5/6/2009 10:27:23 PMDrew
I get a SHOCK on BOTH of my Vintage Radios, eg. Mod 444. If it SHOCKS when Switch is OFF. Reversing plug, It then SHOCKS when ON. This is GREAT SITE, Thanks, Drew
5/7/2009 1:28:54 AMNorm Leal
Hi Drew
Some AC/DC radios are like that. There will be a capacitor from one side of the line to radio chassis. Switch is wired in the ground side of the line to keep hum down. A radio wired this way will shock you either when the switch is on or off, depending on plug polarity.
Even though you feel a shock there is little current. There will only be a small spark if chassis come in contact with a ground wire.
None of this will be a problem once a radio is in the cabinet with knobs attached. Cabinet and knobs will isolate the chassis.
If your radio is a metal Arvin or similar it's a problem. You could rewire the switch so it's in hot side of the AC line and use a polarized plug.
:I get a SHOCK on BOTH of my Vintage Radios, eg. Mod 444. If it SHOCKS when Switch is OFF. Reversing plug, It then SHOCKS when ON. This is GREAT SITE, Thanks, Drew
5/8/2009 7:32:10 PMDrew
:Hi Drew
: Some AC/DC radios are like that. There will be a capacitor from one side of the line to radio chassis. Switch is wired in the ground side of the line to keep hum down. A radio wired this way will shock you either when the switch is on or off, depending on plug polarity.
: Even though you feel a shock there is little current. There will only be a small spark if chassis come in contact with a ground wire.
: None of this will be a problem once a radio is in the cabinet with knobs attached. Cabinet and knobs will isolate the chassis.
: If your radio is a metal Arvin or similar it's a problem. You could rewire the switch so it's in hot side of the AC line and use a polarized plug.
::I get a SHOCK on BOTH of my Vintage Radios, eg. Mod 444. If it SHOCKS when Switch is OFF. Reversing plug, It then SHOCKS when ON. This is GREAT SITE, Thanks, Drew
5/8/2009 7:35:12 PMDrew
Thank You.
5/7/2009 2:29:34 AMWarren
I have repaired and restored many of the Hallicrafters S-38 line. These have a metal cabinet with the hot chassis. Your AC/DC radio has the same power supply setup. Here is a good link on how to deal with this and make it safe
http://www.the-s38-guy.com/Page_2.html
5/8/2009 7:34:28 PMDrew
Thank you
