:Greetings,
:I have an old radio with a dull, bent, and cracked back.
:I glued the cracks with duco cement and dampened the cardboard and put it under flat weights and it appears to be working. Is there another way to repair these backs? and is there a way to bring the color or appearance back to life and maybe strenghten them with some kind of coating?
:Thank you,
:Vinny A.
:Marv, thank you for your time and knowledge in responding. I guess when I shop for the material it is called masonite?
:Marv, how do you get the labels off without destroying them?
:Thank you,
:Vinny
:If you have an old clipboard, that does make a good radio back. Easy to cut, file, and fit with vent holes and all. If you do have the old back, you can use it as a template.
: Hi Vinny, I had to reproduce a back on a radio and couldn't get the decals off. They started to fall apart. I scanned them on the computer and did a little work in pro paints, they came out perfect and looked original used plain paper and sprayed with a couple light coats of lacquer then put them on with a light coat of spray adhesive to the back of the label. I used masonite for the back. Get a Sabre saw and a couple good files, they are easy to reproduce. Best 2 U, George T
:Thank you everyone for the suggestions.
:I have found a couple of old clipboards that look so authentic that I will try. Also the boards with the holes are a great idea also, thank you again.
:There is a plethera of wisdom on this website second to none. I could not have gone this far with this hobby if it were not for you guru's.
:Vinny A.
Pegboard, the kind with little holes punched or drilled in it about one inch apart for putting little hooks and things in is a great Masonite product for radio backs, you get lots of cooling air through the holes.
