Any thoughts ?
Hi Adam,
I recently went through an "EMUD" German radio that used the electrostatic tweeter speakers. Mine also had no output. Turned out to be the material used to back-up the diaphram with...it's like a styrofoam material...over the years becomes so brittle it will just disintegrate to the touch. Also found poor (green) connections of the membrane material for the diaphram - at the point of connection. I used a 1/4" thick piece of shipping styrofoam to replace the disintegrated stuff with...and just cleaned the diaphram connections up. Worked fine!
Good luck with your speakers ( I wasn't aware of Zenith using the electrostatic tweeters in sets)
Joe
