5/1/2009 5:19:00 AMJesse Hancock(73642:0)
This is driving me nuts ! I cant find the caps Im looking for online. Does anyone know where you can locate close to exact values found in a Radio? Ive checked MCM, and all the other online sources and trying to find the right values.. Im stumped.
5/1/2009 8:37:11 AMRogers flipdial(73645:73642)
Post the actual value and voltage here and someone will point you in the right direction.
5/1/2009 11:32:09 AMNorm Leal(73648:73642)
Hi Jesse
Both AES, www.tubesandmore.com and Radio Daze, www.radiodaze.com sell caps and other parts for radios. Just Radios is a good supplier for caps, www.justradios.com .
:This is driving me nuts ! I cant find the caps Im looking for online. Does anyone know where you can locate close to exact values found in a Radio? Ive checked MCM, and all the other online sources and trying to find the right values.. Im stumped.
5/6/2009 9:49:06 AMBob Masse(73861:73648)
:Hi Jesse
: Both AES, www.tubesandmore.com and Radio Daze, www.radiodaze.com sell caps and other parts for radios. Just Radios is a good supplier for caps, www.justradios.com .
:Hi! Jessy,
For a beginner, capacitors can be very confusing but if you go to www.justradios.com website, as Norm suggested , you will find a heading called "capacitor tips". Here you will find a great deal of info on capacitors and it is free.If you google the, ( Phil's Old Radios),site follow the links and click on the "beginner" heading, there is a load of info on old radios and it is free. There you will find the section "why and how to replace capacitors" ,which has a full explanation and pictures of various capacitors used in old radios. I printed the info from both sites and put it in a folder so that I can refresh my memory from time to time.Hope this helps. Bob Masse
::This is driving me nuts ! I cant find the caps Im looking for online. Does anyone know where you can locate close to exact values found in a Radio? Ive checked MCM, and all the other online sources and trying to find the right values.. Im stumped.
5/1/2009 5:05:41 PMdave at just radios will put a kit together(73653:73642)
just send an email to dave at justradios with your model number and he will send you a kit specifically for your radio. nice and easy to deal with chap
5/2/2009 11:36:07 PM!-(73710:73653)
:just send an email to dave at justradios with your model number and he will send you a kit specifically for your radio. nice and easy to deal with chap
5/6/2009 8:25:34 AMDennis Wess(73859:73642)
Could you perhaps be trying to match values that are no longer produced ?
For example.....trying to find a .05uf cap, which was a common value 50 years ago,is pretty tough. Nowadays this value is replaced with a .047uf cap, etc., etc.
5/6/2009 1:46:33 PMEd M(73877:73642)
Except for tuned circuits, capacitor values are seldom critical. Use at least the rated voltage of the original capacitor. Except for electrolytic, capacitance values within plus 50% or minus 20% of original is still very conservative. (I go larger than original; set manufacturers tended to use the smallest / cheapest capacitor they could.) Electrolytics should be the original voltage rating, or the next highest available; up to 100% over the original capacitance value will seldom cause problems. However in a power supply with choke and / or field coil choke, check voltages carefully, as a value different from plus or minus 30% may create a resonant situation, and result in instability or overvoltage.
Ed M
5/12/2009 4:38:27 PMjess tanis(74052:73642)
5/12/2009 4:55:21 PMNorm Leal(74053:74052)
Hi Jess
What values are you looking for?
Exact values aren't critical. Old value of .05 mf has been replaced by .047 mf. You can always use a higher voltage rating. 600 volt caps will replace 200 or 400 volt rated.
For filter caps 10 mf can replace 8 mf, 22 replaces 16 or 20 mf.
Dave at justradios can get you what's required.
