:I need to replace a 1 Meg linear Pot in my radio. But the problem is that it has a tap. Is there any way to get around this by using a fixed resistor to mimic the tap? I assume the tap is just a fixed resistance from either of the 2 ends of the pot. Anyone else have this problem? Thanks...
Are you talking about multiple taps, because most pots have center taps. The tap is the moving part where the variable resistance is measured.
The 2 other connections are the ends of the resistor.
So, if it is a 1Mohm pot - you will measure 1Mohm across the 2 outer terminals all the time. The center tap will be increasing with reference to one side and decreasing WRT the other terminal when the pot is turned in a certain direction (clockwise vs. counter-clockwise). See example below (for reference only, the directions may be different). It will be the opposite effect when turned in the other direction. Maybe I am oversimplifying your question.
2
CW<- | ->CCW
1 ---/\/\/\/\/----3
::I need to replace a 1 Meg linear Pot in my radio. But the problem is that it has a tap. Is there any way to get around this by using a fixed resistor to mimic the tap? I assume the tap is just a fixed resistance from either of the 2 ends of the pot. Anyone else have this problem? Thanks...
Steve
:Steve -
:Are you talking about multiple taps, because most pots have center taps. The tap is the moving part where the variable resistance is measured.
:The 2 other connections are the ends of the resistor.
:So, if it is a 1Mohm pot - you will measure 1Mohm across the 2 outer terminals all the time. The center tap will be increasing with reference to one side and decreasing WRT the other terminal when the pot is turned in a certain direction (clockwise vs. counter-clockwise). See example below (for reference only, the directions may be different). It will be the opposite effect when turned in the other direction. Maybe I am oversimplifying your question.
: 2
: CW<- | ->CCW
:1 ---/\/\/\/\/----3
:Dave
:::I need to replace a 1 Meg linear Pot in my radio. But the problem is that it has a tap. Is there any way to get around this by using a fixed resistor to mimic the tap? I assume the tap is just a fixed resistance from either of the 2 ends of the pot. Anyone else have this problem? Thanks...
:Hi Dave,
:This tap is addition to the beginning, end and variable tap. This tap seems to have a fixed resistance to either end. I think this was done for the same reasons that they used multi-capacitor packs, to save on money. I would think there would be a good way to expand that section to accommodate a couple of fixed resistors which would be equivalent to what I have there now...
:Steve
::Steve -
::Are you talking about multiple taps, because most pots have center taps. The tap is the moving part where the variable resistance is measured.
::The 2 other connections are the ends of the resistor.
::So, if it is a 1Mohm pot - you will measure 1Mohm across the 2 outer terminals all the time. The center tap will be increasing with reference to one side and decreasing WRT the other terminal when the pot is turned in a certain direction (clockwise vs. counter-clockwise). See example below (for reference only, the directions may be different). It will be the opposite effect when turned in the other direction. Maybe I am oversimplifying your question.
:: 2
:: CW<- | ->CCW
::1 ---/\/\/\/\/----3
::Dave
::::I need to replace a 1 Meg linear Pot in my radio. But the problem is that it has a tap. Is there any way to get around this by using a fixed resistor to mimic the tap? I assume the tap is just a fixed resistance from either of the 2 ends of the pot. Anyone else have this problem? Thanks...
If I knew the make and model of the radio, I could make a much better judgement.
Steve - If you just connect an ohmmeter btwn each of the different terminals as you adjust the pot, you will know what they are doing and be able to replace that functionality. If part of it remains fixed, then it could probably be replaced by a fixed resistor in series.
As Lewis noted, knowing the model number would help. Then, we should be able to check the schematic and see what the circuit looks like.
http://sound.westhost.com/pots.htm
Steve, that is most likely for tone control as mentioned and you can not add a fixed resister in parallel or series as the effect will vary the resistance of the over all circuit. You will have to find and old pot. of if your handy you can try what I did. Get new pot same resistance, open it up, find position on resistance path to get the center tap resistance, use conductive paint and bring out "lead to edge of pot,be carful not to get paint on resistance strip in path of wiper, hardest part was making terminal lug, I used #2 nut and bolt from hobby store, also file out a notch in cover so when you re-assemble pot it won't short out paint to cover. This was a PITA but so far its working. Ideally, if you could find those terminal pins that were used on early circuit boards it would be easy. Those pins were about 1/16" in dia and you would put thenm in hole and use a dies to "rivit" them into board. PL
Come forth with the maker and model of your set and we can research and see what the true situation Use your pointer index referencing to then to find MID / CENTER rotation position of the pot. In that testing manner, your readings would have now fully identified a linear pots resistive response. NOW, should you have a LOGARITHMIC, or audio taper. . . .the common type used for a volume control. . . . On the log pot, the resistance change from max CCW position is so condensed, that it seems to take for-ev-ah to make a pronounced change of the resistance value of the portion that is deposited upon the pots resistance element in the portion between the max CCW rotor /wiper position and its mid
4/27/2009 3:29:53 PMSteve Bento(73495:73491) Sorry for the lack of info - it's a Grunow 660. This is for the volume control and not the tone because the radio already has a separate tone control. Ed's right - I need to determine if this is indeed a linear taper or an audio taper. I assumed it was linear but could very well be wrong. But it sounds like planigan's idea would be worth trying. I am getting a fixed resistance from that tap of about 230k from the 0 ohm terminal. 4/27/2009 4:54:43 PMLewis L(73496:73495) :Sorry for the lack of info - it's a Grunow 660. This is for the volume control and not the tone because the radio already has a separate tone control. Ed's right - I need to determine if this is indeed a linear taper or an audio taper. I assumed it was linear but could very well be wrong. But it sounds like planigan's idea would be worth trying. I am getting a fixed resistance from that tap of about 230k from the 0 ohm terminal.
4/27/2009 4:56:30 PMLewis L(73497:73496) ::Sorry for the lack of info - it's a Grunow 660. This is for the volume control and not the tone because the radio already has a separate tone control. Ed's right - I need to determine if this is indeed a linear taper or an audio taper. I assumed it was linear but could very well be wrong. But it sounds like planigan's idea would be worth trying. I am getting a fixed resistance from that tap of about 230k from the 0 ohm terminal. : : :Now that I've seen the schematic, I can tell you that the tap is for loudness control, that is, the ear hears frequencies at different volume levels. You will need a log pot, and if there is not a tap, you probably will not ever notice the difference. But if you are like me, you will want a one meg pot with a loudness tap. Not an uncommon animal. Lewis
4/27/2009 6:05:42 PMplanigan(73499:73496) ::Sorry for the lack of info - it's a Grunow 660. This is for the volume control and not the tone because the radio already has a separate tone control. Ed's right - I need to determine if this is indeed a linear taper or an audio taper. I assumed it was linear but could very well be wrong. But it sounds like planigan's idea would be worth trying. I am getting a fixed resistance from that tap of about 230k from the 0 ohm terminal. : : :Now that I've seen the schematic, I can tell you that the tap is for loudness control, that is, the ear hears frequencies at different volume levels. You will need a log pot, and if there is not a tap, you probably will not ever notice the difference. But if you are like me, you will want a one meg pot with a loudness tap. Not an uncommon animal. :Lewis
© 1989-2025, Nostalgia Air |
