The instruction that I found on Riders 8-24... say for SW band "C" (5-18mhz) to set the dial to 18mhz and adj cap-K for max,
Then they say to set to 16.5mhz and adj cap-L (under chassis) for max. while rocking the tuner.
Ok great.. I can see that for 18mhz... ok got it no problem... but which trimmer under the chassis is "L" ??
I think it is the one I labeled #3... but then what are caps # 1 and #2 for?
Hi Peter
I found your schematic in my Zenith Service manual.
I am going to my company to pick up some tools so I will copy the two pages on your set. If you have a fax number I can sent them two you when I get back.
Page 1 is the schematic.
Page 2 has Socket voltages, Alignment procedures and a picture showing location of trimmers. Maybe between the schematic and picture you can figure out which trimmer does what.
Larry
Peter,
I was able to copy both pages of the Zenith Service Manual to PDF format.
If you send your e-mail I will be happy to send them to you.
Larry
