Admiral F5
4/16/2009 10:34:39 PMIan
Hi, just got one of these. the chassis is marked F5 NOT 5f, Does anyone have the schematic for this?
It has 11 tubes 10+eye
4/16/2009 11:24:13 PMCarl T
:Hi, just got one of these. the chassis is marked F5 NOT 5f, Does anyone have the schematic for this?
:It has 11 tubes 10+eye
:Thanks
Ian,
The only info I see on an F5 shows it as a 5 tube set.
Can you post the complete tube line up?
Carl T
4/16/2009 11:34:26 PMIan
2x 6f6
2x 6c5
1x 5z3
1x 6u5
1x 6h6
3x 6k7
1x 6a8
::Hi, just got one of these. the chassis is marked F5 NOT 5f, Does anyone have the schematic for this?
::It has 11 tubes 10+eye
::Thanks
:Ian,
:The only info I see on an F5 shows it as a 5 tube set.
:Can you post the complete tube line up?
:Carl T
4/17/2009 3:39:05 PMCarl T
Jon,
This is the schematic that I found:
http://www.nostalgiaair.org/PagesByModel/064/M0003064.pdf
Schematic shows a 6A7, but tube layout shows a 6A8.
Carl T
:2x 6f6
:2x 6c5
:1x 5z3
:1x 6u5
:1x 6h6
:3x 6k7
:1x 6a8
:::Hi, just got one of these. the chassis is marked F5 NOT 5f, Does anyone have the schematic for this?
:::It has 11 tubes 10+eye
:::Thanks
::Ian,
::The only info I see on an F5 shows it as a 5 tube set.
::Can you post the complete tube line up?
::Carl T
4/18/2009 2:31:33 PMxxxx xxxx
:Jon,
:This is the schematic that I found:
:http://www.nostalgiaair.org/PagesByModel/064/M0003064.pdf
:Schematic shows a 6A7, but tube layout shows a 6A8.
:Carl T
::2x 6f6
::2x 6c5
::1x 5z3
::1x 6u5
::1x 6h6
::3x 6k7
::1x 6a8
::::Hi, just got one of these. the chassis is marked F5 NOT 5f, Does anyone have the schematic for this?
::::It has 11 tubes 10+eye
::::Thanks
:::Ian,
:::The only info I see on an F5 shows it as a 5 tube set.
:::Can you post the complete tube line up?
:::Carl T
4/20/2009 9:05:41 PMIan
Thats it!
THanks for helping me.
When I took the chassis out of the cabinet (which included the total destruction of the cassis mount board) I discovered About 5 lbs of mouse materials(paper, fur, Cloth) and the skeletons of 18 dead mice. This should be an interesting restoration...
:Jon,
:Carl T
::2x 6f6
::2x 6c5
::1x 5z3
::1x 6u5
::1x 6h6
::3x 6k7
::1x 6a8
::::Thanks
:::Ian,
:::Carl T
