Heathkit TC-2
4/16/2009 5:06:29 PMMike
Hi would any one have a manual for a heathkit tc-2 also does anyone have the updated charts that were on this site for it. Or is it against copy write for them.
Mike
4/16/2009 9:14:17 PMBob Masse
:Hi would any one have a manual for a heathkit tc-2 also does anyone have the updated charts that were on this site for it. Or is it against copy write for them.
:Thanks
:Mike
:Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
4/18/2009 7:17:32 PMBill
::Hi would any one have a manual for a heathkit tc-2 also does anyone have the updated charts that were on this site for it. Or is it against copy write for them.
::Thanks
::Mike
::Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
4/21/2009 10:11:25 PMMike
:::Hi would any one have a manual for a heathkit tc-2 also does anyone have the updated charts that were on this site for it. Or is it against copy write for them.
:::Thanks
:::Mike
:::Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
Bob thanks again that was a great help. It filled in the gaps of some tubes I didnt have data for. Go figure it would be for newer tubes. I usally only like the old old once lol.
Just another question if anyone has this data sheet. I have been looking for a test set up for the older Rogers 32 Type tube not the standard 32 tube. It would be the same as the Rogers 20 type tube as well.
Thanks again Mike
4/22/2009 12:03:58 AMplanigan
::::Hi would any one have a manual for a heathkit tc-2 also does anyone have the updated charts that were on this site for it. Or is it against copy write for them.
::::Thanks
::::Mike
::::Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
:Bob thanks again that was a great help. It filled in the gaps of some tubes I didnt have data for. Go figure it would be for newer tubes. I usally only like the old old once lol.
:Just another question if anyone has this data sheet. I have been looking for a test set up for the older Rogers 32 Type tube not the standard 32 tube. It would be the same as the Rogers 20 type tube as well.
:Thanks again Mike
Mike, EICO 625 settings for 20 and 32 tube are as follows:
20: 48 6.3 2 2,3 4
32: 42 2.0 2 2,3,10 4 (bold)
I am not familiar with Rogers tube differences. PL
4/22/2009 3:47:08 PMAnthony
Hi Mike, Could you forward the manual and any tube data sheets to me, I purchased a heathkit tc-1 with no manuals or info. Thanks Tony My e-mail is bigtoeknee@verizon.net
:::::Thanks
:::::Mike
:::::Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
::Bob thanks again that was a great help. It filled in the gaps of some tubes I didnt have data for. Go figure it would be for newer tubes. I usally only like the old old once lol.
::Just another question if anyone has this data sheet. I have been looking for a test set up for the older Rogers 32 Type tube not the standard 32 tube. It would be the same as the Rogers 20 type tube as well.
::Thanks again Mike
:Mike, EICO 625 settings for 20 and 32 tube are as follows:
: 20: 48 6.3 2 2,3 4
: 32: 42 2.0 2 2,3,10 4 (bold)
: I am not familiar with Rogers tube differences. PL
4/23/2009 11:09:42 AMBob Masse
: Hi Mike, Could you forward the manual and any tube data sheets to me, I purchased a heathkit tc-1 with no manuals or info. Thanks Tony My e-mail is bigtoeknee@verizon.net
::::::Thanks
::::::Mike
::::::Hi! Mike, Check your email. I sent you a partial manual which at least tells how to operate the tester.Maybe someone will have a complete one to send to you. I also sent a tube data supplement and a schematic. Hope this helps. Good Luck! Bob Masse
:::Bob thanks again that was a great help. It filled in the gaps of some tubes I didnt have data for. Go figure it would be for newer tubes. I usally only like the old old once lol.
:::Just another question if anyone has this data sheet. I have been looking for a test set up for the older Rogers 32 Type tube not the standard 32 tube. It would be the same as the Rogers 20 type tube as well.
:::Thanks again Mike
::Mike, EICO 625 settings for 20 and 32 tube are as follows:
:: 20: 48 6.3 2 2,3 4
:: 32: 42 2.0 2 2,3,10 4 (bold)
:: I am not familiar with Rogers tube differences. PL
: Hi! Tony, Check your email, info sent. Bob Masse
