2/2/2001 6:24:30 PMTommy Stueart(7309:0)
Help!! I am in need of settings for a precision 10-40 Tube tester to test 8950 tubes.
thanx
3/18/2003 9:42:49 PMkevin(20743:7309)
:Help!! I am in need of settings for a precision 10-40 Tube tester to test 8950 tubes.
:thanx
3/18/2003 9:47:31 PMkevin(20744:20743)
::Help!! I am in need of settings for a precision 10-40 Tube tester to test 8950 tubes.
::thanx im not sure what the settings are ither did you ever find out for the 8950 iwas told that they are the same as the 6LQ6 i use that setting but im still uncertain if this is the correct setting.
