Paint spatter on Bakelite
4/11/2009 9:13:10 PMVinny
Greetings,
Can anyone suggest a method of removing paint splatter on Bakelite.
Thank You,
Vinny A.
4/11/2009 9:56:55 PMDoug H
:Greetings,
:Can anyone suggest a method of removing paint splatter on Bakelite.
:Thank You,
:Vinny A.
It will depend a lot on what kind of paint that splattered on it, but I have been successful using DuPont 7 Rubbing Compound (Automotive) followed by Turtle Wax Polishing Compound & Scratch Remover. (also Automotive) If that doesn't work, I then use Wright's All Purpose Brass Polish. Go over the entire Bakelite case with the Wright's, it really cleans and makes it shine.
4/11/2009 10:15:18 PMvinny
Doug, thank you for responding.
I am using Weinman's brass polish right now and it is working nicely. Thank you.
Vinny A.
::Greetings,
::Can anyone suggest a method of removing paint splatter on Bakelite.
::Thank You,
::Vinny A.
:It will depend a lot on what kind of paint that splattered on it, but I have been successful using DuPont 7 Rubbing Compound (Automotive) followed by Turtle Wax Polishing Compound & Scratch Remover. (also Automotive) If that doesn't work, I then use Wright's All Purpose Brass Polish. Go over the entire Bakelite case with the Wright's, it really cleans and makes it shine.
4/30/2009 10:48:17 PMJeff Watson
Bakelite (make sure it is bakelite and not plastic) is impervious to paint stripper.
::Greetings,
::Thank You,
::Vinny A.
5/6/2009 12:50:15 PMVinny
Jeff, thank you for your time and knowledge.
Vinny A.
