:Hey, all. Looking for some ideas about a problem with this radio. Sometimes (but not every time) after it has been on for a couple of minutes or longer, the volume will start to drop until there is just a hum. After a few minutes, the volume slowly comes back up and the radio plays normally. I was hoping that the problem would worsen so that it would be easier to locate. I hate intermittent problems like this. I have replaced various resistors, paper caps, and the electrolytics in previous repairs. Any thoughts about what to look at first? Mark from Kalamazoo
Mark:
Are you married? If so, does your wife have a hair dryer? Do you have a Radio Shack nearby? If so, do they have cooling spray? Assemble the preceeding while study the schematic and we'll get together later.
When the volume drops, and then comes back up, does it then stay up? Or does it keep going through cycles?
It'll take a while, but you can monitor the plate and other voltages of each tube, and see if one of them drops when volume drops. I would start with the oscillator section and then the RF and IF sections. The audio section may be OK, since you hear hum when the volume drops.
Doug
::Now, come on you guys! someone must have some ideas about where to start looking. Anyone? Mark from Kalamazoo
:::Hey, all. Looking for some ideas about a problem with this radio. Sometimes (but not every time) after it has been on for a couple of minutes or longer, the volume will start to drop until there is just a hum. After a few minutes, the volume slowly comes back up and the radio plays normally. I was hoping that the problem would worsen so that it would be easier to locate. I hate intermittent problems like this. I have replaced various resistors, paper caps, and the electrolytics in previous repairs. Any thoughts about what to look at first? Mark from Kalamazoo
:Mark:
:Are you married? If so, does your wife have a hair dryer? Do you have a Radio Shack nearby? If so, do they have cooling spray? Assemble the preceeding while study the schematic and we'll get together later.
:Lewis
You have replaced the filter caps, right?
Doug
Yeah, I seem to recall that he did. I think the way to go is with heat and cold and let's see what develops. Oh, I can't find a schematic, either.
ZENITH SCHEMATIC RESUBMISSION: ![]() |
: : : : ![]() : : : : : : : :Sir Mark: : : :If that were my set to evaluate (and, snifff. . .alas. . .its not ) , again, I would be doing this: : : : : :Re Quote" : : :For a more exacting audio evaluation…pump one channel of a CD / DVD players audio into the phono input, or tie into the top of the vol-you-me control, should it not already have a phono input, as is shown on the back, but with this being the deluxe version, I think that it will. . . . . : :" End Quote : : :Then you would be using the unit and :listening to it for that typical onset of failure time period, and that would give some degree of confirmation of the AUDIO section past the volume control and the power supply not being at fault. : : :BTW is this problem ocurring on BOTH AYE-EMM and EFF-EMM reception modes ? Edd: Yes, it's happening on both AM and FM. But, now it hasn't happened that last several times I have played it. Right now, it's been on for an hour without any problem. Arrgh. Yes, I thought about feeding another source in through the phono jack. With intermittent problems, I find I must just keeping playing the radio until it becomes a constant problem and thus easier to find. Mark from Kalamazoo : : :73's de Edd :: ![]() :: :: :: :: |
: : :ZENITH SCHEMATIC RESUBMISSION: : : : : ![]() : : : : |
